Fuel Pump Seals? |
Fuel Pump Seals? |
dlo914 |
Nov 7 2004, 02:51 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
discovered my fuel pump is leaking, havent had the chance to pull it out and have a close look, but from crawling underneath the car it seems to be leaking from the pump. a buddy says id be able to replace the seals or possibly have it rebuilt. where would i be able to get these seals, or where could i get the pump rebuilt? not quite fond of the price of a "new" pump. OR could i just replace the one on the 14 with a pump off a bus?
DJsRepS |
Nov 7 2004, 02:21 PM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Unless you have +$200 for new it can be fixed with a couple of O rings from the hardware store. After you pry the tabs and split the housing apart the housing oring is easy to change. The one that leaks is around the terminal plug its easy too if your good with a solder iron. Mine had alot of brush wear on the armature but keeps 32psi pressure at RPM's. Also +70psi test return hose at regulator pluged. Pic of freon shradder valve silver soldered on the OEM test port.
Attached image(s) |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:34 AM |
