Fuse box cover, buy a new cover or a new panel |
slotty008 |
Dec 10 2017, 03:57 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
The cover of my fuse box is missing. I can buy a new cover from Sierra Madre or get a new fuse panel. But Jwest doesn't have it at the moment and Pelican neither. I could buy a 12 way fuse box on Ebay but I'm not sure it will fit
I have had no electrical issues, so what would be the best thing to do? |
mepstein |
Dec 10 2017, 04:15 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
First, I’m a big believer in using all new fuses. Spend $5-10 and replace them all.
Second, the original fuse panel is simple and works fine. Clean up the contacts. I found a second panel, cleaned it off in vinegar and then switched the wires, one by one, into the clean panel. Then cleaned the old one so I could do the same for the next car. I would just get a new cover. The old ones get brittle and crack. Attached image(s) |
slotty008 |
Dec 10 2017, 04:20 PM
First, I’m a big believer in using all new fuses. Spend $5-10 and replace them all. Second, the original fuse panel is simple and works fine. Clean up the contacts. I found a second panel, cleaned it off in vinegar and then switched the wires, one by one, into the clean panel. Then cleaned the old one so I could do the same for the next car. I would just get a new cover. The old ones get brittle and crack. Not a bad idea! |
Lo-Fi Version | Time is now: 11th June 2024 - 04:34 AM |
