Heat Control Flapper Valves, Are the valves on each side the same? |
db9146 |
Dec 3 2017, 07:05 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Got a question on the heater control flapper valves on a -6. On mine, the driver side flapper has a solid cap over one side of the flapper valve while the passenger side flapper valve has a hole about 1.5" in diameter in the cap.
Anyone know the a reason for the one having a hole? |
mepstein |
Dec 12 2017, 06:23 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think it was 1- 1 1/4”. It was a wurth hole saw that I chucked into the drill press. Drilled the hole, blasted the piece and then powder coated. I had 5 that were pretty rusty but still usable. I hope to make a pair or 2.
I think bdstone charges ~$50 for refurbished flapper boxes. By the time you throw out the broken ones, fix the ones that can be fixed, blast and powder coat, $50+ is a good deal. |
Lo-Fi Version | Time is now: 29th May 2024 - 05:27 AM |
