smog pump delete 1976 2.0 cali car |
dax1969 |
Dec 14 2017, 07:08 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi guys,
Tried the search option but can't find what I'm looking for. I know that the Cali 1976 914 2.0 has a smog pump/system to pass emission test. If such a system is not needed in your area, would you remove it or leave in place ? Will you gain more power without this system ? If you remove the pump should you only block of the lines with caps you can buy at AA or else or are there any other modifications needed ? Other exhaust ? thks yr advise krgds Dax |
914Sixer |
Dec 14 2017, 08:13 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All 75-76 have the smog pump and air injection system. I removed mine because it restricts the horsepower. You can cap the injection tubes. Remove all the plumbing and pump. Pump has a fan hub shaft at fails and there are no replacements at this time. Exhaust is also restrictive. Best to backdate to 73-74 exhaust. Late exhaust tend to fall apart. By removing all of that stuff you should be able to gain about 7 hp.
Lo-Fi Version | Time is now: 9th June 2024 - 08:27 AM |
