1975 1.8L Engine |
1975 1.8L Engine |
DennisO |
Dec 13 2017, 09:29 AM
Member Group: Members Posts: 61 Joined: 9-June 17 From: Clayton, NC Member No.: 21,162 Region Association: South East States |
Hi All,
I finally had a chance to pull the engine from my 1975 914 Project. It was actually a lot easier then I thought it would be. There was a lot of great info in this forum that helped make it so easy. I searched the forum, but could not find an answer. I think I know the answer, but I'll ask the question, just to be sure. Did the 1.8L engines come from the factor with the engine block painted red? see the attached picture. Also, now that the engine is pulled I was able to inspect the hell hole and inner longitudinal areas. There is some minor surface rust, but overall it looks great. It does not look like it will need any rust repair! Thanks. Attached thumbnail(s) |
914Sixer |
Dec 17 2017, 06:39 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Heads were not seated properly. Hence the exhaust leaks. Mismatch of valves though. The one with S is a sodium valve.
Lo-Fi Version | Time is now: 9th June 2024 - 12:10 AM |
