> Handiest torque wrench for 914 Type 4?
98101
post Dec 18 2017, 04:12 PM
Michael in Seattle
I want to remove and replace my Dellortos and the instructions are to torque to [EDITED] 13 inch-lbs. Most of you know what that feels like intuitively, but I'm a newbie and don't want to screw up my new toy.
I don't yet own a torque wrench -- don't think I've even used one before. I'm wondering which one I should buy for this and future 914 stuff. E.g. my valve covers are converted to bolt on.
iankarr
post Dec 18 2017, 09:29 PM
I find this digital 3/8 wrench super handy. Range is 2-37 ft/lbs, which is in the sweet spot for a lot of stuff. Especially the sensitive ones like the oil strainer / sump bolt, rocker assembly nuts and exhaust manifold nuts. It makes progressively faster beeps till you reach your target. It displays in .10 increments
https://www.amazon.com/gp/product/B004VYUQI...=UTF8&psc=1
I also have a click-type 1/2" 20-150 (good for wheel lugs) and a 3/4 50-300 monster for big stuff like the axle nuts.
98101   Handiest torque wrench for 914 Type 4?   Dec 18 2017, 04:12 PM
BillC   I want to remove and replace my Dellortos and the...   Dec 18 2017, 05:13 PM
98101   I want to remove and replace my Dellortos and th...   Dec 18 2017, 05:21 PM
BillC   I'd rather spend a little more than damage the...   Dec 18 2017, 05:36 PM
barefoot   The carb studs are M8 size & typical torque va...   Dec 18 2017, 05:27 PM
98101   The carb studs are M8 size & typical torque v...   Dec 18 2017, 08:27 PM
Valy   [quote name='barefoot' post='2558932' date='Dec 1...   Dec 19 2017, 12:00 AM
MarkV   Those gaskets are probably deformed from heat or a...   Dec 18 2017, 09:06 PM
cuddyk   I find this digital 3/8 wrench super handy. Range ...   Dec 18 2017, 09:29 PM
thelogo   If you cannot operate the torque wrench you do not...   Dec 18 2017, 09:36 PM
98101   If you cannot operate the torque wrench you do no...   Dec 18 2017, 10:03 PM
mepstein   I’m in the same boat as you but I’m learning. ...   Dec 18 2017, 10:22 PM
MarkV   I grew up with a dad that didn't know his way ...   Dec 18 2017, 10:24 PM
thelogo   All true guys and i respect your enthusiasm for w...   Dec 18 2017, 11:31 PM
Mueller   I broke a flange on a T5 Tremec transmission using...   Dec 18 2017, 11:50 PM
Mark Henry   I want to remove and replace my Dellortos and the...   Dec 19 2017, 07:12 AM
Olympic 914   I use a Snap-on torque wrench that is 5-75 ft lbs ...   Dec 19 2017, 07:40 AM
Vacca Rabite   Its NOT inch pounds. Its foot pounds. Don't r...   Dec 19 2017, 08:58 AM
98101   Don't reuse the neoprene gaskets. Use the ph...   Dec 19 2017, 10:59 AM
jesse7flying   Not to intrude on the OP, but I have a set of Webe...   Dec 19 2017, 10:31 AM
MarkV   The phenolic spacers for the manifold to head is c...   Dec 19 2017, 10:49 AM
Tbrown4x4   Those are manifold to 2.0L head gaskets. Insulates...   Dec 19 2017, 11:14 AM
MarkV   [quote name='Vacca Rabite' post='2559122' date='D...   Dec 19 2017, 11:15 AM
Vacca Rabite   The phenolic spacers with the paper gaskets attach...   Dec 19 2017, 11:32 AM
98101   I reached the previous owner (Tim), who told me he...   Dec 19 2017, 07:25 PM
Olympic 914   Whistle Gaskets .... :rotfl: Sounds like Snake...   Dec 19 2017, 07:58 PM
Vacca Rabite   Try them. Maybe snake oil, maybe not. But they a...   Dec 20 2017, 09:15 AM
jd74914   Whistle Gaskets .... :rotfl: Sounds like Snak...   Dec 20 2017, 09:45 AM
Mark Henry   I've installed them a few times, I know they w...   Dec 20 2017, 10:23 AM
MarkV   Someone on a 356 board said he filled the void wit...   Dec 20 2017, 10:41 AM
porschetub   Someone on a 356 board said he filled the void wi...   Dec 20 2017, 01:01 PM
98101   UPDATE: I tried spraying water around the deformed...   Dec 20 2017, 10:12 PM
MarkV   In your first photo it looks to me like because of...   Dec 20 2017, 10:52 PM
98101   Seems like previous owner left you with some east...   Dec 20 2017, 11:45 PM
thelogo   :agree: on a big monster motor like that Every th...   Dec 20 2017, 11:25 PM
MarkV   Previous owner mistakes are commonly highlighted a...   Dec 20 2017, 11:57 PM
98101   No disrespect intended to previous owners.   Dec 21 2017, 02:27 AM
90quattrocoupe   This is the only place I buy torque wrenches. I u...   Dec 25 2017, 01:46 PM
The Cabinetmaker   "But I didn't learn until driving to two ...   Dec 26 2017, 11:19 AM
98101   I'm not surprised you had a hard time finding...   Dec 26 2017, 04:32 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:12 PM
