> Handiest torque wrench for 914 Type 4?
98101
post Dec 18 2017, 04:12 PM
Michael in Seattle
I want to remove and replace my Dellortos and the instructions are to torque to [EDITED] 13 inch-lbs. Most of you know what that feels like intuitively, but I'm a newbie and don't want to screw up my new toy.
I don't yet own a torque wrench -- don't think I've even used one before. I'm wondering which one I should buy for this and future 914 stuff. E.g. my valve covers are converted to bolt on.
Mark Henry
post Dec 19 2017, 07:12 AM
that's what I do!
QUOTE(98101 @ Dec 18 2017, 05:12 PM) *
13 inch pounds would be like farting on a feather, so I'm sure it meant 13 foot pounds, which converted would be 156 inch pounds.
I made up a inch pound to foot pound conversion chart and hung it above my bench.
I have both an inch pound torque wrench that converted goes to 22 ft/lbs and a foot pound wrench to 25- 200 ft/lbs.
I strongly recommend you get both, to me the inch pound is important for doing the oil sump plate on a four.
BTW that dell carb gasket likely has it's own special torque value, just like 911 silicone valve cove gaskets, they can't take full spec torque because they squeeze out or deform.
98101   Handiest torque wrench for 914 Type 4?   Dec 18 2017, 04:12 PM
BillC   I want to remove and replace my Dellortos and the...   Dec 18 2017, 05:13 PM
98101   I want to remove and replace my Dellortos and th...   Dec 18 2017, 05:21 PM
BillC   I'd rather spend a little more than damage the...   Dec 18 2017, 05:36 PM
barefoot   The carb studs are M8 size & typical torque va...   Dec 18 2017, 05:27 PM
98101   The carb studs are M8 size & typical torque v...   Dec 18 2017, 08:27 PM
Valy   [quote name='barefoot' post='2558932' date='Dec 1...   Dec 19 2017, 12:00 AM
MarkV   Those gaskets are probably deformed from heat or a...   Dec 18 2017, 09:06 PM
cuddyk   I find this digital 3/8 wrench super handy. Range ...   Dec 18 2017, 09:29 PM
thelogo   If you cannot operate the torque wrench you do not...   Dec 18 2017, 09:36 PM
98101   If you cannot operate the torque wrench you do no...   Dec 18 2017, 10:03 PM
mepstein   I’m in the same boat as you but I’m learning. ...   Dec 18 2017, 10:22 PM
MarkV   I grew up with a dad that didn't know his way ...   Dec 18 2017, 10:24 PM
thelogo   All true guys and i respect your enthusiasm for w...   Dec 18 2017, 11:31 PM
Mueller   I broke a flange on a T5 Tremec transmission using...   Dec 18 2017, 11:50 PM
Mark Henry   I want to remove and replace my Dellortos and the...   Dec 19 2017, 07:12 AM
Olympic 914   I use a Snap-on torque wrench that is 5-75 ft lbs ...   Dec 19 2017, 07:40 AM
Vacca Rabite   Its NOT inch pounds. Its foot pounds. Don't r...   Dec 19 2017, 08:58 AM
98101   Don't reuse the neoprene gaskets. Use the ph...   Dec 19 2017, 10:59 AM
jesse7flying   Not to intrude on the OP, but I have a set of Webe...   Dec 19 2017, 10:31 AM
MarkV   The phenolic spacers for the manifold to head is c...   Dec 19 2017, 10:49 AM
Tbrown4x4   Those are manifold to 2.0L head gaskets. Insulates...   Dec 19 2017, 11:14 AM
MarkV   [quote name='Vacca Rabite' post='2559122' date='D...   Dec 19 2017, 11:15 AM
Vacca Rabite   The phenolic spacers with the paper gaskets attach...   Dec 19 2017, 11:32 AM
98101   I reached the previous owner (Tim), who told me he...   Dec 19 2017, 07:25 PM
Olympic 914   Whistle Gaskets .... :rotfl: Sounds like Snake...   Dec 19 2017, 07:58 PM
Vacca Rabite   Try them. Maybe snake oil, maybe not. But they a...   Dec 20 2017, 09:15 AM
jd74914   Whistle Gaskets .... :rotfl: Sounds like Snak...   Dec 20 2017, 09:45 AM
Mark Henry   I've installed them a few times, I know they w...   Dec 20 2017, 10:23 AM
MarkV   Someone on a 356 board said he filled the void wit...   Dec 20 2017, 10:41 AM
porschetub   Someone on a 356 board said he filled the void wi...   Dec 20 2017, 01:01 PM
98101   UPDATE: I tried spraying water around the deformed...   Dec 20 2017, 10:12 PM
MarkV   In your first photo it looks to me like because of...   Dec 20 2017, 10:52 PM
98101   Seems like previous owner left you with some east...   Dec 20 2017, 11:45 PM
thelogo   :agree: on a big monster motor like that Every th...   Dec 20 2017, 11:25 PM
MarkV   Previous owner mistakes are commonly highlighted a...   Dec 20 2017, 11:57 PM
98101   No disrespect intended to previous owners.   Dec 21 2017, 02:27 AM
90quattrocoupe   This is the only place I buy torque wrenches. I u...   Dec 25 2017, 01:46 PM
The Cabinetmaker   "But I didn't learn until driving to two ...   Dec 26 2017, 11:19 AM
98101   I'm not surprised you had a hard time finding...   Dec 26 2017, 04:32 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:31 PM
