| 98101 |
Dec 18 2017, 04:12 PM
Michael in Seattle ![]() ![]() Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I want to remove and replace my Dellortos and the instructions are to torque to [EDITED] 13 inch-lbs. Most of you know what that feels like intuitively, but I'm a newbie and don't want to screw up my new toy.
I don't yet own a torque wrench -- don't think I've even used one before. I'm wondering which one I should buy for this and future 914 stuff. E.g. my valve covers are converted to bolt on. |
| MarkV |
Dec 19 2017, 10:49 AM
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
The phenolic spacers for the manifold to head is common like on injection. They have a thin gasket attached to both sides. Maybe someone makes a similar gasket for manifold to carb.
(IMG:style_emoticons/default/confused24.gif) |
98101 Handiest torque wrench for 914 Type 4? Dec 18 2017, 04:12 PM
BillC
I want to remove and replace my Dellortos and the... Dec 18 2017, 05:13 PM
98101
I want to remove and replace my Dellortos and th... Dec 18 2017, 05:21 PM
BillC I'd rather spend a little more than damage the... Dec 18 2017, 05:36 PM
barefoot The carb studs are M8 size & typical torque va... Dec 18 2017, 05:27 PM
98101
The carb studs are M8 size & typical torque v... Dec 18 2017, 08:27 PM
Valy
[quote name='barefoot' post='2558932' date='Dec 1... Dec 19 2017, 12:00 AM
MarkV Those gaskets are probably deformed from heat or a... Dec 18 2017, 09:06 PM
cuddyk I find this digital 3/8 wrench super handy. Range ... Dec 18 2017, 09:29 PM
thelogo If you cannot operate the torque wrench you do not... Dec 18 2017, 09:36 PM
98101
If you cannot operate the torque wrench you do no... Dec 18 2017, 10:03 PM
mepstein I’m in the same boat as you but I’m learning. ... Dec 18 2017, 10:22 PM
MarkV I grew up with a dad that didn't know his way ... Dec 18 2017, 10:24 PM
thelogo All true guys and i respect your enthusiasm for w... Dec 18 2017, 11:31 PM
Mueller I broke a flange on a T5 Tremec transmission using... Dec 18 2017, 11:50 PM
Mark Henry
I want to remove and replace my Dellortos and the... Dec 19 2017, 07:12 AM
Olympic 914 I use a Snap-on torque wrench that is 5-75 ft lbs ... Dec 19 2017, 07:40 AM
Vacca Rabite Its NOT inch pounds. Its foot pounds.
Don't r... Dec 19 2017, 08:58 AM
98101
Don't reuse the neoprene gaskets. Use the ph... Dec 19 2017, 10:59 AM
jesse7flying Not to intrude on the OP, but I have a set of Webe... Dec 19 2017, 10:31 AM
Tbrown4x4 Those are manifold to 2.0L head gaskets. Insulates... Dec 19 2017, 11:14 AM
MarkV
[quote name='Vacca Rabite' post='2559122' date='D... Dec 19 2017, 11:15 AM
Vacca Rabite The phenolic spacers with the paper gaskets attach... Dec 19 2017, 11:32 AM
98101 I reached the previous owner (Tim), who told me he... Dec 19 2017, 07:25 PM
Olympic 914 Whistle Gaskets .... :rotfl:
Sounds like Snake... Dec 19 2017, 07:58 PM
Vacca Rabite Try them. Maybe snake oil, maybe not.
But they a... Dec 20 2017, 09:15 AM
jd74914
Sounds like Snak... Dec 20 2017, 09:45 AM
Mark Henry I've installed them a few times, I know they w... Dec 20 2017, 10:23 AM
MarkV Someone on a 356 board said he filled the void wit... Dec 20 2017, 10:41 AM
porschetub
Someone on a 356 board said he filled the void wi... Dec 20 2017, 01:01 PM
98101 UPDATE: I tried spraying water around the deformed... Dec 20 2017, 10:12 PM
MarkV In your first photo it looks to me like because of... Dec 20 2017, 10:52 PM
98101
Seems like previous owner left you with some east... Dec 20 2017, 11:45 PM
thelogo :agree: on a big monster motor like that
Every th... Dec 20 2017, 11:25 PM
MarkV Previous owner mistakes are commonly highlighted a... Dec 20 2017, 11:57 PM
98101 No disrespect intended to previous owners. Dec 21 2017, 02:27 AM
90quattrocoupe This is the only place I buy torque wrenches. I u... Dec 25 2017, 01:46 PM
The Cabinetmaker "But I didn't learn until driving to two ... Dec 26 2017, 11:19 AM
98101
I'm not surprised you had a hard time finding... Dec 26 2017, 04:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:29 PM |
