| 98101 |
Dec 18 2017, 04:12 PM
Michael in Seattle ![]() ![]() Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I want to remove and replace my Dellortos and the instructions are to torque to [EDITED] 13 inch-lbs. Most of you know what that feels like intuitively, but I'm a newbie and don't want to screw up my new toy.
I don't yet own a torque wrench -- don't think I've even used one before. I'm wondering which one I should buy for this and future 914 stuff. E.g. my valve covers are converted to bolt on. |
| VaccaRabite |
Dec 19 2017, 11:32 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
The phenolic spacers with the paper gaskets attached can be found at all the usual places you get 914 parts.
They are engine size specific, but its EASY to ID them. 4 bolt holes vs 3 bolt holes. 4 bolt holes are for 1.7 and 1.8 engines. 3 bolt holes are for 2.0 engines. Zach |
98101 Handiest torque wrench for 914 Type 4? Dec 18 2017, 04:12 PM
BillC
I want to remove and replace my Dellortos and the... Dec 18 2017, 05:13 PM
98101
I want to remove and replace my Dellortos and th... Dec 18 2017, 05:21 PM
BillC I'd rather spend a little more than damage the... Dec 18 2017, 05:36 PM
barefoot The carb studs are M8 size & typical torque va... Dec 18 2017, 05:27 PM
98101
The carb studs are M8 size & typical torque v... Dec 18 2017, 08:27 PM
Valy
[quote name='barefoot' post='2558932' date='Dec 1... Dec 19 2017, 12:00 AM
MarkV Those gaskets are probably deformed from heat or a... Dec 18 2017, 09:06 PM
cuddyk I find this digital 3/8 wrench super handy. Range ... Dec 18 2017, 09:29 PM
thelogo If you cannot operate the torque wrench you do not... Dec 18 2017, 09:36 PM
98101
If you cannot operate the torque wrench you do no... Dec 18 2017, 10:03 PM
mepstein I’m in the same boat as you but I’m learning. ... Dec 18 2017, 10:22 PM
MarkV I grew up with a dad that didn't know his way ... Dec 18 2017, 10:24 PM
thelogo All true guys and i respect your enthusiasm for w... Dec 18 2017, 11:31 PM
Mueller I broke a flange on a T5 Tremec transmission using... Dec 18 2017, 11:50 PM
Mark Henry
I want to remove and replace my Dellortos and the... Dec 19 2017, 07:12 AM
Olympic 914 I use a Snap-on torque wrench that is 5-75 ft lbs ... Dec 19 2017, 07:40 AM
Vacca Rabite Its NOT inch pounds. Its foot pounds.
Don't r... Dec 19 2017, 08:58 AM
98101
Don't reuse the neoprene gaskets. Use the ph... Dec 19 2017, 10:59 AM
jesse7flying Not to intrude on the OP, but I have a set of Webe... Dec 19 2017, 10:31 AM
MarkV The phenolic spacers for the manifold to head is c... Dec 19 2017, 10:49 AM
Tbrown4x4 Those are manifold to 2.0L head gaskets. Insulates... Dec 19 2017, 11:14 AM
MarkV
[quote name='Vacca Rabite' post='2559122' date='D... Dec 19 2017, 11:15 AM
98101 I reached the previous owner (Tim), who told me he... Dec 19 2017, 07:25 PM
Olympic 914 Whistle Gaskets .... :rotfl:
Sounds like Snake... Dec 19 2017, 07:58 PM
Vacca Rabite Try them. Maybe snake oil, maybe not.
But they a... Dec 20 2017, 09:15 AM
jd74914
Sounds like Snak... Dec 20 2017, 09:45 AM
Mark Henry I've installed them a few times, I know they w... Dec 20 2017, 10:23 AM
MarkV Someone on a 356 board said he filled the void wit... Dec 20 2017, 10:41 AM
porschetub
Someone on a 356 board said he filled the void wi... Dec 20 2017, 01:01 PM
98101 UPDATE: I tried spraying water around the deformed... Dec 20 2017, 10:12 PM
MarkV In your first photo it looks to me like because of... Dec 20 2017, 10:52 PM
98101
Seems like previous owner left you with some east... Dec 20 2017, 11:45 PM
thelogo :agree: on a big monster motor like that
Every th... Dec 20 2017, 11:25 PM
MarkV Previous owner mistakes are commonly highlighted a... Dec 20 2017, 11:57 PM
98101 No disrespect intended to previous owners. Dec 21 2017, 02:27 AM
90quattrocoupe This is the only place I buy torque wrenches. I u... Dec 25 2017, 01:46 PM
The Cabinetmaker "But I didn't learn until driving to two ... Dec 26 2017, 11:19 AM
98101
I'm not surprised you had a hard time finding... Dec 26 2017, 04:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:39 PM |
