| barefoot |
Jan 3 2018, 02:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
New 2L build case align bored and gallery plugs replaced with threaded plugs so i know everything's clean in there. New CB type 1 oil pump mod the fit Tp 4. Temporary oil pressure gage fitted, Valvoline VR-1 20W-50 oil and all bearings pre-lubed with assembly lube (the red stuff)
With my test rig I'm trying to make sure oil pressure observed before trying to fire the engine. Spark plugs pulled, so easy cranking. I've now cranked it over perhaps 30 revs so far and no pressure showing yet. I did not pre-fill oil filter (not sure why that's a bad idea) I pulled filter and there was ~ 1/4 full, so it seems oil's getting somewhere, but how long does it take to build pressure ??? |
| Montreal914 |
Jan 3 2018, 04:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,053 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Takes a little while.
Are these 2.0 HE or 1.7–1.8? Good looking engine and trans! Came break in. |
| barefoot |
Jan 3 2018, 05:29 PM
Takes a little while. Are these 2.0 HE or 1.7–1.8? Good looking engine and trans! Cam break in. 1.7-1.8 H/E's, yes want to run the engine on my little test rig for cam break-in cycle. Will then re-torque heads and check valve clearance before loading into car. Will have 40 Dell's and my fuel system will be an elevated tank to provide 3 psi Not sure if I'll ned to add the muffler, time will tell ! |
barefoot Building oil pressure on new build Jan 3 2018, 02:17 PM
Vacca Rabite Assuming you have pulled the spark plugs out...
Ju... Jan 3 2018, 03:13 PM
jcd914 :agree: Jan 3 2018, 03:44 PM
914forme Just let the starter rest a bit. You can also bu... Jan 3 2018, 04:08 PM
Vacca Rabite Put the muffler on. Once the muffler is on you ha... Jan 3 2018, 08:15 PM
ndfrigi
New 2L build case align bored and gallery plugs r... Jan 3 2018, 09:44 PM
falcor75 For me it takes about 3 to 6 ten second bursts fro... Jan 4 2018, 12:19 AM
barefoot After WAY too much starter cranking and still no o... Jan 6 2018, 02:33 PM
76-914 It's a good idea to loosen the oil filter, cra... Jan 6 2018, 08:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 05:00 AM |
