Crankcase Breathers |
McMark |
Sep 12 2017, 04:58 PM
I was looking at the factory manuals and talking with someone about crankcase breathers. We were talking about breather setups for carbs specifically. And I realized as I was looking at the breather diagram that it appears that the breather ports on the heads were included to supply extra air to flow through the engine case. And then I read this little snipped in the manuals which seems to support my thought:
QUOTE Crankcase ventilation has been considerably improved in the engine by ducting fresh air from the air filter. This modification reduces crankcase condensation and icing at low outside temperatures. So following that logic... If the crankcase breather (at the oil filler neck) isn't connected to a vacuum source, then the ports at the heads should/could be plugged instead of connected to a breather box. Thoughts? Contradictions? Agreement? I realize people have been connecting breathers all sorts of different ways and most work just fine. I'm more interested in the theory aspect, and refining an 'ideal' installation since we already know many ways to 'make it work'. Attached image(s) |
gothspeed |
Jan 4 2018, 11:14 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
^^^ looks good! is there any baffle, foam or mesh in the catch can or empty?
On another note after reading a bit on breathers (including raby's link previouly posted) , I wonder if anyone has actually measured the air pressure in the valve covers? There is information that under some circumstances, the valve cover cavity can get high levels of oil. Does anyone know if this was with or without a valve cover vent? |
ChrisFoley |
Jan 5 2018, 07:42 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
^^^ looks good! is there any baffle, foam or mesh in the catch can or empty? On another note after reading a bit on breathers (including raby's link previouly posted) , I wonder if anyone has actually measured the air pressure in the valve covers? There is information that under some circumstances, the valve cover cavity can get high levels of oil. Does anyone know if this was with or without a valve cover vent? Foam in the inner chamber of the canister. Air pressure inside the crankcase is no more than a couple inches of water column. Ie, a small fraction of one psi. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:35 AM |
