My DIY raised spindles. How to |
jmitro |
Jan 6 2018, 08:33 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Here is my process for raising spindles on standard 914 boge strut bodies. As documented elsewhere this modification allows you to lower the car but maintain correct camber curve and suspension travel. Raising by 19 mm allows use of 15”, 16”, or 17” wheels. I have converted to 5 lug using 911 front strut bodies, so my learning curve was to first modify these 914 struts. First photo is comparison of stock unmodified left side 914 strut body versus modified right side (my first one).
Attached thumbnail(s) |
jmitro |
Jan 6 2018, 08:43 AM
In my haste to complete the project, I forgot to photograph the second half of the modification which includes cutting off the ball joint end and welding an external sleeve to return the strut to original length. This is a 2.01" ID x 2.25" OD sleeve. Again a EDIT 1.75" OD tube was inserted to ensure precise alignment, and orientation of the ball joint pin hole was maintained
Lo-Fi Version | Time is now: 17th June 2024 - 12:55 AM |
