| barefoot |
Jan 3 2018, 02:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
New 2L build case align bored and gallery plugs replaced with threaded plugs so i know everything's clean in there. New CB type 1 oil pump mod the fit Tp 4. Temporary oil pressure gage fitted, Valvoline VR-1 20W-50 oil and all bearings pre-lubed with assembly lube (the red stuff)
With my test rig I'm trying to make sure oil pressure observed before trying to fire the engine. Spark plugs pulled, so easy cranking. I've now cranked it over perhaps 30 revs so far and no pressure showing yet. I did not pre-fill oil filter (not sure why that's a bad idea) I pulled filter and there was ~ 1/4 full, so it seems oil's getting somewhere, but how long does it take to build pressure ??? |
| 76-914 |
Jan 6 2018, 08:28 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
It's a good idea to loosen the oil filter, crank until oil starts to seep out then tighten the filter. Nice work! (IMG:style_emoticons/default/beerchug.gif)
barefoot Building oil pressure on new build Jan 3 2018, 02:17 PM
Vacca Rabite Assuming you have pulled the spark plugs out...
Ju... Jan 3 2018, 03:13 PM
jcd914 :agree: Jan 3 2018, 03:44 PM
914forme Just let the starter rest a bit. You can also bu... Jan 3 2018, 04:08 PM
Montreal914 Takes a little while.
Are these 2.0 HE or 1.7–1.... Jan 3 2018, 04:17 PM
barefoot
Are these 2.0 HE or 1.7–1... Jan 3 2018, 05:29 PM
Vacca Rabite Put the muffler on. Once the muffler is on you ha... Jan 3 2018, 08:15 PM
ndfrigi
New 2L build case align bored and gallery plugs r... Jan 3 2018, 09:44 PM
falcor75 For me it takes about 3 to 6 ten second bursts fro... Jan 4 2018, 12:19 AM
barefoot After WAY too much starter cranking and still no o... Jan 6 2018, 02:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 05:02 AM |
