Carburetor throats stopped matching |
98101 |
Jan 7 2018, 11:07 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I pulled the carbs to install a new linkage, and blew out the jets while I was at it. The two carbs are synchronized with each other better than they've ever been, but now there's a discrepancy within one of the carbs (DRLA 45s). I'm wondering if I bent a throttle plate, or if there's something else I did that could cause this?
The lower one is cylinder 3, if that matters. There was a slight discrepancy before, but now they're further apart. |
rhodyguy |
Jan 8 2018, 08:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are the air by pass screws in the same adjustment they were when you started the carb work? Did you preset them equally while going thru the preinstall procedure? New linkage...start at the beginning. What is your idle rpm? What are the readings when you measure the l&r front venturi flow at a stable idle? Equal?
Lo-Fi Version | Time is now: 9th June 2024 - 06:56 PM |
