Carburetor throats stopped matching |
98101 |
Jan 7 2018, 11:07 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I pulled the carbs to install a new linkage, and blew out the jets while I was at it. The two carbs are synchronized with each other better than they've ever been, but now there's a discrepancy within one of the carbs (DRLA 45s). I'm wondering if I bent a throttle plate, or if there's something else I did that could cause this?
The lower one is cylinder 3, if that matters. There was a slight discrepancy before, but now they're further apart. |
MarkV |
Jan 8 2018, 08:16 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Thank you everyone. Indeed the air bypass screws weren't seated. ALL FOUR OF THEM. We screwed those back in and checked the stacks, but no change. VW mechanic feels the throttle shaft is bent. This is the carb that doesn't leak as much gasoline on itself as the one on the other side. Throttle shaft is pretty stout and would be hard to bend. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:31 PM |
