jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
Here is my process for raising spindles on standard 914 boge strut bodies. As documented elsewhere this modification allows you to lower the car but maintain correct camber curve and suspension travel. Raising by 19 mm allows use of 15”, 16”, or 17” wheels. I have converted to 5 lug using 911 front strut bodies, so my learning curve was to first modify these 914 struts. First photo is comparison of stock unmodified left side 914 strut body versus modified right side (my first one).
Attached thumbnail(s) ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I've never tried this.
I always thought you could just grind out the welds holding the spindle assembly and slide it up. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:34 AM |
