| hockeymutt |
Dec 31 2017, 11:19 AM
Member ![]() ![]() Group: Members Posts: 84 Joined: 4-August 08 From: NJ Member No.: 9,388 Region Association: None |
Hey everyone starting to get the pieces for my swap, currently have a WRX engine with complete harness. Picked it up for 1k complete with engine harness and body harness 80k on the motor. here are my questions:
Cooling: MR2 radiator with dual fans in the front? VW reservoir for self bleeding SIDE NOTE: I've been really interested in maybe doing something under the front bumper looks like porsche made a Mid mount radiator but my concern is its way to small (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn4.pelicanparts.com-9388-1514740760.1.jpg) the other option is doing a deck lid mounted set up with 2 porsche mid mount radiators and using push pull flow fans, but can't find anyone that has succeeded with it? Cradle have a few options but leads me to my next question: TRANS: do i keep the stock and use the kenny adapters? about $800-900 or can pick up a forester trans with 160k for $175 plus axle splines, bell crank cables, shifter, pedal assembly with cylinders, 2wd conversion, GPS speedo, plus man hours i'll prob be close to $1500 to convert. my concerns with the subie trans are i would have to go to a floor mounted pedal set up and would have to figure out how to tie into the stock brake system. Think I've figured it out but seems like a lot of work and tweaking to get the bias correct. Resplined axles from dutchman should be easy, Cable bell crank is available online, 2wd is easy to get. thanks for all the help, this will be a long journey but will be worth it. (IMG:style_emoticons/default/headbang.gif) |
| 914GT |
Jan 11 2018, 06:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I mounted a pair of small fans under my engine lid on my V8 conversion to get more airflow around the engine and carb. Initially I had these exhausting the hot air up and out through the lid, which seemed best since hot air rises. With this arrangement I soon had a very dirty and dusty engine and engine compartment. Dirt and debris off the road gets sucked up and covers everything. So I flipped the fans around so they blow down. Something else to consider with a radiator in the back and if you’re pulling air up from the bottom of the car.
hockeymutt subi conversion questions Dec 31 2017, 11:19 AM
mepstein I think you will be happier going all suby. Now th... Dec 31 2017, 11:40 AM
flmont Is there a subie tranns thats all cable actuated,.... Dec 31 2017, 12:08 PM
hockeymutt
Is there a subie tranns thats all cable actuated,... Dec 31 2017, 12:31 PM
Is there a subie tranns thats all cable actuated,... Dec 31 2017, 01:47 PM
Mike Bellis All of it is doable if you have skills. Forget the... Dec 31 2017, 01:02 PM
hockeymutt
All of it is doable if you have skills. Forget th... Dec 31 2017, 01:30 PM
mepstein I don't think you can go light on cooling with... Dec 31 2017, 01:31 PM
914forme I will highly recommend Zero Decibels linkage, it ... Dec 31 2017, 06:00 PM
hockeymutt
I will highly recommend Zero Decibels linkage, it... Dec 31 2017, 07:17 PM
76-914 You don’t need a custom 3 pedal set. The stock o... Dec 31 2017, 06:25 PM
thelogo Sorry but if you are a aircraft mechanic
Then y... Dec 31 2017, 06:29 PM
hockeymutt
Then ... Dec 31 2017, 07:07 PM
Front yard mechanic
Then ... Dec 31 2017, 07:18 PM
thelogo
Who would want a crappy Honda motor might as well... Dec 31 2017, 07:46 PM
76-914
Then ... Jan 1 2018, 11:18 AM
Sleepin As a Subie guy, I would also recommend a Killer B ... Dec 31 2017, 09:01 PM
Andyrew Everything Mike Bellis has said. Read his thread, ... Jan 1 2018, 01:26 AM
A&P Mech Hockeymutt, welcome to the madness that is Subaru ... Jan 1 2018, 11:08 AM
Mr. M What year of Celica are you using for the radiator... Jan 1 2018, 11:38 AM
thelogo I would not want to flare the car only to accommod... Jan 1 2018, 02:03 PM
rnellums Mid 90s Jeep Cherokee radiator is the perfect size... Jan 1 2018, 02:32 PM
Mid 90s Jeep Cherokee radiator is the perfect siz... Jan 1 2018, 03:12 PM
A&P Mech
What year of Celica are you using for the radiato... Jan 1 2018, 02:58 PM
Mike Bellis
What year of Celica are you using for the radiat... Jan 1 2018, 06:36 PM
hockeymutt
Hockeymutt, welcome to the madness that is Subaru... Jan 1 2018, 06:27 PM
thelogo This is cool
Radiator is totally packaged
And fr... Jan 1 2018, 07:11 PM
A&P Mech Hockeymutt this is a very good build thread that c... Jan 1 2018, 08:13 PM
rnellums
If it’s a street car, it’s the 95 degree day ... Jan 2 2018, 04:45 AM
Rotary'14
[quote name='mepstein' post='2563314' date='Jan 1... Jan 12 2018, 07:30 AM
914forme Cherokee Rad
Overall Size: 35" x 11.50... Jan 2 2018, 12:08 PM
hockeymutt finally was able to complete the wrx engine and ha... Jan 2 2018, 06:48 PM
Sleepin A V mount radiator and intercooler would be awesom... Jan 2 2018, 07:31 PM
hockeymutt Trying to figure out the subaru trans right now. ... Jan 10 2018, 04:02 PM
mgp4591 The idea of the radiator on the engine lid is inte... Jan 10 2018, 11:54 PM
914forme Add rubber skirting, a M1A1 Tank fan, and a snow m... Jan 11 2018, 08:26 AM
76-914 I wouldn't put the radiator back there even if... Jan 11 2018, 08:28 AM
mgp4591
I wouldn't put the radiator back there even i... Jan 11 2018, 11:51 PM
zipedadoo Bobcat skid steer loaders use a similar radiator s... Jan 11 2018, 08:53 AM
rnellums
The MT5 cases changed some say the latter ones ar... Jan 12 2018, 10:19 PM
hockeymutt Picked up a 5mt. found a very knowledge fabricator... Jan 12 2018, 11:15 PM
rnellums
Picked up a 5mt. found a very knowledge fabricato... Jan 13 2018, 09:02 AM
hockeymutt
Picked up a 5mt. found a very knowledge fabricat... Jan 13 2018, 05:57 PM
rnellums
thats what i was thinking. Going to see about get... Jan 13 2018, 09:58 PM
hockeymutt
thats what i was thinking. Going to see about ge... Jan 13 2018, 10:10 PM
rnellums
Hahah once you have a turbo car you never want to... Jan 13 2018, 10:20 PM
JRust
Hahah once you have a turbo car you never want t... Jan 14 2018, 03:21 PM
rnellums
I should have mine ready for Route 66 this year. ... Jan 14 2018, 06:07 PM
hockeymutt http://www.914world.com/bbs2/uploads_offsite/image... Jan 13 2018, 05:36 PM
hockeymutt So starting to get back into this as its been warm... Feb 17 2018, 11:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:34 AM |
