> Craigslist 914 Mechanic, Is this person a member here?
1adam12
post Jan 13 2018, 06:29 PM
I've seen this ad on craigslist (Los Angeles) offering 914 help. Just wondering if this person Brian is a member here. Looking for some local help with my car but not going to spend $250 for a Porsche mechanic to just inspect it.
https://losangeles.craigslist.org/wst/cto/d...6416309419.html
I need someone to recheck my valve adjustment, timing, dizzy and to bring a working MPS. I'm pretty sure I've screwed all this up as my 1.7l won't turn over now.
Montreal914
post Jan 13 2018, 08:45 PM
If it was running before you pulled out the distributor (BTW why? (IMG:style_emoticons/default/confused24.gif) ) then, as you mentioned, your probably too far off with your timing to start. Couple of options, either do a static timing to get you close or have someone turn the key while you turn the distributor until it starts.
These are old cars but reliable when everything is in order. The more you play with it, (IMG:style_emoticons/default/smash.gif) the more you will enjoy your car. (IMG:style_emoticons/default/driving.gif)
Good luck, plenty of help here. (IMG:style_emoticons/default/beerchug.gif)
1adam12
post Jan 13 2018, 08:55 PM
QUOTE(Montreal914 @ Jan 13 2018, 06:45 PM) *
Thank you Montreal914 and Mark for the support. I was just getting to the point of frustration after attempting to clean and adjust the points on the dizzy. It seems there's a small margin in error on a 914 from not running, running and running good! It would be nice to follow someone through the steps in person just to assure I'm doing things the correct way and not lose an entire weekend chasing existing problems or ones that ive created (IMG:style_emoticons/default/dry.gif)
1adam12   Craigslist 914 Mechanic   Jan 13 2018, 06:29 PM
mgphoto   Ok, lets start with your terminology? Turn over, s...   Jan 13 2018, 07:29 PM
1adam12   Ok, lets start with your terminology? Turn over, ...   Jan 13 2018, 07:45 PM
Mikey914   Sounds like you might get somefree advice as to we...   Jan 13 2018, 07:31 PM
Montreal914   If it was running before you pulled out the distri...   Jan 13 2018, 08:45 PM
1adam12   If it was running before you pulled out the distr...   Jan 13 2018, 08:55 PM
r_towle   You are near Los Angeles. Go find a local VW airco...   Jan 13 2018, 09:00 PM
914werke   Thank you Montreal914 and Mark for the support. I...   Jan 13 2018, 09:45 PM
Tom_T   Near-ish to you in OC, you can try either Bill Bre...   Jan 13 2018, 09:48 PM
thelogo   Ive seen the same add And it seems to good to be...   Jan 13 2018, 09:59 PM
Mueller   Ive seen the same add And it seems to good to b...   Jan 14 2018, 01:06 PM
thelogo   [quote name='thelogo' post='2567945' date='Jan 13...   Jan 14 2018, 01:26 PM
get off my lawn   How do you get to know someone well without mee...   Jan 18 2018, 06:00 PM
Tdskip   Do you feel comfortable with the idea of static ti...   Jan 13 2018, 10:55 PM
KELTY360   Have you called him to see if he's a member he...   Jan 13 2018, 11:19 PM
Andyrew   If that was on my local craigslist you can guarant...   Jan 14 2018, 01:35 AM
r_towle   The car is running a vw bus motor, so it’s fairl...   Jan 14 2018, 09:56 AM
76-914   Be sure that the molex plug at the Dist hasn't...   Jan 14 2018, 11:42 AM
914_teener   Maybe I can help you out. I'm in Glendora and...   Jan 14 2018, 01:00 PM
bdstone914   I have not heard of him before. I could suggest a...   Jan 14 2018, 11:01 PM
Larmo63   :agree: Bruce helped me out A LOT when I was try...   Jan 15 2018, 01:03 AM
bdstone914   Looking more at the ad I would probably not use wh...   Jan 15 2018, 07:30 AM
craig downs   I live in Eastvale which is close to you. I'm ...   Jan 15 2018, 12:02 PM
7TPorsh   What kind of points setup in the dizzy? Is it per...   Jan 16 2018, 10:46 AM
1adam12   Thanks to everyones input here, I really appreciat...   Jan 16 2018, 03:00 PM
snakemain   Odd coincidence with the "Oh Happy Day" ...   Jan 16 2018, 08:45 PM
nimblemotorsports   right off the bat, I'd say DO NOT use this guy...   Jan 17 2018, 07:32 PM
Front yard mechanic   right off the bat, I'd say DO NOT use this gu...   Jan 18 2018, 08:13 AM
1adam12   FINALLY! FINALLY! FINALLY! Got her ru...   Jan 18 2018, 03:07 PM
The Cabinetmaker   Sometimes its the simple things in life that give ...   Jan 18 2018, 03:37 PM
cmxiv 74   Hi, Good you fixed your problems. My opinion about...   Feb 5 2018, 02:43 AM
Lucky9146   Hi, Good you fixed your problems. My opinion abou...   Feb 5 2018, 09:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:17 AM
