> Craigslist 914 Mechanic, Is this person a member here?
1adam12
post Jan 13 2018, 06:29 PM
I've seen this ad on craigslist (Los Angeles) offering 914 help. Just wondering if this person Brian is a member here. Looking for some local help with my car but not going to spend $250 for a Porsche mechanic to just inspect it.
https://losangeles.craigslist.org/wst/cto/d...6416309419.html
I need someone to recheck my valve adjustment, timing, dizzy and to bring a working MPS. I'm pretty sure I've screwed all this up as my 1.7l won't turn over now.
thelogo
post Jan 13 2018, 09:59 PM
Group: Retired Members
Ive seen the same add
And it seems to good to be true
I wish i could find a guy like that
Cause i never have time to take the car to my goto
Wrench , who has 25 years aircooled experience and a machine shop
But this is a 914 not a bug with a stock 1600
So id stay away from anybody i dont know well
Mueller
post Jan 14 2018, 01:06 PM
914 Freak!
QUOTE(thelogo @ Jan 13 2018, 07:59 PM) *
How do you get to know someone well without meeting them and hanging out?
Osmosis? (IMG:style_emoticons/default/poke.gif)
A few minutes on the phone and you should be able to tell if knows a few things about the cars to make it worth your time to have see or work on the car.
If people didn't advertise they'd have hard time expanding their customer base.
1adam12   Craigslist 914 Mechanic   Jan 13 2018, 06:29 PM
mgphoto   Ok, lets start with your terminology? Turn over, s...   Jan 13 2018, 07:29 PM
1adam12   Ok, lets start with your terminology? Turn over, ...   Jan 13 2018, 07:45 PM
Mikey914   Sounds like you might get somefree advice as to we...   Jan 13 2018, 07:31 PM
Montreal914   If it was running before you pulled out the distri...   Jan 13 2018, 08:45 PM
1adam12   If it was running before you pulled out the distr...   Jan 13 2018, 08:55 PM
r_towle   You are near Los Angeles. Go find a local VW airco...   Jan 13 2018, 09:00 PM
914werke   Thank you Montreal914 and Mark for the support. I...   Jan 13 2018, 09:45 PM
Tom_T   Near-ish to you in OC, you can try either Bill Bre...   Jan 13 2018, 09:48 PM
thelogo   Ive seen the same add And it seems to good to be...   Jan 13 2018, 09:59 PM
Mueller   Ive seen the same add And it seems to good to b...   Jan 14 2018, 01:06 PM
thelogo   [quote name='thelogo' post='2567945' date='Jan 13...   Jan 14 2018, 01:26 PM
get off my lawn   How do you get to know someone well without mee...   Jan 18 2018, 06:00 PM
Tdskip   Do you feel comfortable with the idea of static ti...   Jan 13 2018, 10:55 PM
KELTY360   Have you called him to see if he's a member he...   Jan 13 2018, 11:19 PM
Andyrew   If that was on my local craigslist you can guarant...   Jan 14 2018, 01:35 AM
r_towle   The car is running a vw bus motor, so it’s fairl...   Jan 14 2018, 09:56 AM
76-914   Be sure that the molex plug at the Dist hasn't...   Jan 14 2018, 11:42 AM
914_teener   Maybe I can help you out. I'm in Glendora and...   Jan 14 2018, 01:00 PM
bdstone914   I have not heard of him before. I could suggest a...   Jan 14 2018, 11:01 PM
Larmo63   :agree: Bruce helped me out A LOT when I was try...   Jan 15 2018, 01:03 AM
bdstone914   Looking more at the ad I would probably not use wh...   Jan 15 2018, 07:30 AM
craig downs   I live in Eastvale which is close to you. I'm ...   Jan 15 2018, 12:02 PM
7TPorsh   What kind of points setup in the dizzy? Is it per...   Jan 16 2018, 10:46 AM
1adam12   Thanks to everyones input here, I really appreciat...   Jan 16 2018, 03:00 PM
snakemain   Odd coincidence with the "Oh Happy Day" ...   Jan 16 2018, 08:45 PM
nimblemotorsports   right off the bat, I'd say DO NOT use this guy...   Jan 17 2018, 07:32 PM
Front yard mechanic   right off the bat, I'd say DO NOT use this gu...   Jan 18 2018, 08:13 AM
1adam12   FINALLY! FINALLY! FINALLY! Got her ru...   Jan 18 2018, 03:07 PM
The Cabinetmaker   Sometimes its the simple things in life that give ...   Jan 18 2018, 03:37 PM
cmxiv 74   Hi, Good you fixed your problems. My opinion about...   Feb 5 2018, 02:43 AM
Lucky9146   Hi, Good you fixed your problems. My opinion abou...   Feb 5 2018, 09:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:47 AM
