| Bates |
Jan 15 2018, 09:07 AM
Bates ![]() ![]() Group: Members Posts: 69 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region |
I am doing repairs of my 73 914 chassis in preparation of creating yet another GT clone.
I have started a build thread; GT Build; Flares add flare here; http://www.914world.com/bbs2/index.php?sho...322283&st=0 I thought anyone else who has repaired a 914 may have run into oval rear suspension console mount holes; Here is the suspension pivot , which has a step shoulder on the end that locates the pivot in the suspension console hole. My non digital caliper measures it at .550" ![]() The pivot is one I cut in half to see how it was made, easier to deal with also. Here are pictures of measuring my right side console; ![]() out of focus, but easy to see needle is .030 larger than the step of the shaft ![]() Vertical measurement is .040" larger than the step of the shaft. I want to keep the suspension hole close to original placement, and the original two pieces of stamped plate are in decent condition, so my plan it to make a new locater out of a larger piece of stock; I took a piece of 4140 tubing, .750" o.d., .500" i.d.. First step is to make the i.d. fit the step of the pivot shaft , something just larger than .055". I checked the stock in my lathe and bored the center out to .055" (14mm). ![]() So now I have a shaft to create a 'washer' from that has the perfect inside diameter. I'll take it back to the lathe and 'part' the thickness of the two plates that currently have an oval hole inside. After I have a repair washer that is .750" outside diameter, I'll drill a hole .75" in the oval hole and insert the new washer. ![]() Here is the rough washer, it is a bit warm from machining, so pliers are in order. ![]() Now I'll mark a step bit at the diameter I do not want to exceed with a Sharpie. The red is very visible as I drill, and as soon as I get the hole to the red mark I know to stop. Step drills are good for keeping slightly oval holes on the original hole center when enlarging the hole for repairs. ![]() I took the little washer back to the car, de-burred it and metal finished to clean for welding later. placed it in the .75" hole, holding it there with the stepped shaft for placement; ![]() I then tacked it in place with my MIG welder, and then ground off any 'proud' weld tacks. ![]() I went back after this picture and ran a TIG weld pass around both sides of the new 'washer' . The stepped shaft is now fixed in one location, no moving up and down/ back and forth,. creating havoc when trying to align a suspension. Next step, new roll bar. |
| Andyrew |
Jan 15 2018, 09:50 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Great time to reinforce it as well!
Ecke Liebhaber Repairing an oval suspension mount hole Jan 15 2018, 09:07 AM
brant I agree with Andrew.
now is the time to add reinf... Jan 15 2018, 09:58 AM
Jeff Hail Bushing the enlarged hole was the best way to repa... Jan 17 2018, 07:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 10:53 PM |
