> Craigslist 914 Mechanic, Is this person a member here?
1adam12
post Jan 13 2018, 06:29 PM
I've seen this ad on craigslist (Los Angeles) offering 914 help. Just wondering if this person Brian is a member here. Looking for some local help with my car but not going to spend $250 for a Porsche mechanic to just inspect it.
https://losangeles.craigslist.org/wst/cto/d...6416309419.html
I need someone to recheck my valve adjustment, timing, dizzy and to bring a working MPS. I'm pretty sure I've screwed all this up as my 1.7l won't turn over now.
1adam12
post Jan 16 2018, 03:00 PM
Thanks to everyones input here, I really appreciate it. I actually slept on it after I originally posted. The very next morning with a refreshed mind and attitude, I was able to make some adjustments to the dizzy, double checked timing marks and bam! fired up ' Oh Happy Day'!.
A couple of VW shops I've spoke to in the past told me that they no longer take in 914's hence the discouraging effort to find some local help. I wound up heading down to the Pomona Swap Meet and met Angel of Angels Performance in Anaheim. He stated that he had experience with 914's and would have no problem performing a tune up for $80. Hopefully he has good experience with FI type 4 and can fix the acceleration issue that still exist.
Craig, Brad and other local guys to me, I will be in contact with you soon. I still want to go through some things on my 1.7l first before towing it down to the shop. I ordered a new bosch full pump today and I'm going to recheck all the related grounds.
1adam12   Craigslist 914 Mechanic   Jan 13 2018, 06:29 PM
mgphoto   Ok, lets start with your terminology? Turn over, s...   Jan 13 2018, 07:29 PM
1adam12   Ok, lets start with your terminology? Turn over, ...   Jan 13 2018, 07:45 PM
Mikey914   Sounds like you might get somefree advice as to we...   Jan 13 2018, 07:31 PM
Montreal914   If it was running before you pulled out the distri...   Jan 13 2018, 08:45 PM
1adam12   If it was running before you pulled out the distr...   Jan 13 2018, 08:55 PM
r_towle   You are near Los Angeles. Go find a local VW airco...   Jan 13 2018, 09:00 PM
914werke   Thank you Montreal914 and Mark for the support. I...   Jan 13 2018, 09:45 PM
Tom_T   Near-ish to you in OC, you can try either Bill Bre...   Jan 13 2018, 09:48 PM
thelogo   Ive seen the same add And it seems to good to be...   Jan 13 2018, 09:59 PM
Mueller   Ive seen the same add And it seems to good to b...   Jan 14 2018, 01:06 PM
thelogo   [quote name='thelogo' post='2567945' date='Jan 13...   Jan 14 2018, 01:26 PM
get off my lawn   How do you get to know someone well without mee...   Jan 18 2018, 06:00 PM
Tdskip   Do you feel comfortable with the idea of static ti...   Jan 13 2018, 10:55 PM
KELTY360   Have you called him to see if he's a member he...   Jan 13 2018, 11:19 PM
Andyrew   If that was on my local craigslist you can guarant...   Jan 14 2018, 01:35 AM
r_towle   The car is running a vw bus motor, so it’s fairl...   Jan 14 2018, 09:56 AM
76-914   Be sure that the molex plug at the Dist hasn't...   Jan 14 2018, 11:42 AM
914_teener   Maybe I can help you out. I'm in Glendora and...   Jan 14 2018, 01:00 PM
bdstone914   I have not heard of him before. I could suggest a...   Jan 14 2018, 11:01 PM
Larmo63   :agree: Bruce helped me out A LOT when I was try...   Jan 15 2018, 01:03 AM
bdstone914   Looking more at the ad I would probably not use wh...   Jan 15 2018, 07:30 AM
craig downs   I live in Eastvale which is close to you. I'm ...   Jan 15 2018, 12:02 PM
7TPorsh   What kind of points setup in the dizzy? Is it per...   Jan 16 2018, 10:46 AM
1adam12   Thanks to everyones input here, I really appreciat...   Jan 16 2018, 03:00 PM
snakemain   Odd coincidence with the "Oh Happy Day" ...   Jan 16 2018, 08:45 PM
nimblemotorsports   right off the bat, I'd say DO NOT use this guy...   Jan 17 2018, 07:32 PM
Front yard mechanic   right off the bat, I'd say DO NOT use this gu...   Jan 18 2018, 08:13 AM
1adam12   FINALLY! FINALLY! FINALLY! Got her ru...   Jan 18 2018, 03:07 PM
The Cabinetmaker   Sometimes its the simple things in life that give ...   Jan 18 2018, 03:37 PM
cmxiv 74   Hi, Good you fixed your problems. My opinion about...   Feb 5 2018, 02:43 AM
Lucky9146   Hi, Good you fixed your problems. My opinion abou...   Feb 5 2018, 09:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:17 AM
