Best initial cleaning approach for transmission |
Tdskip |
Jan 18 2018, 07:35 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning. The 901 on my project has already been removed from the car. I need to open it up to replace the 2nd gear synchro and it obviously needs to be clear clean clean before I do that.
Is it safe to pressure wash the exterior case so long as I don’t spray where the input shaft is? And been there / cleaned that tips to share? Thanks! |
NeunEinVier |
Jan 18 2018, 12:47 PM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
Never tried oven cleaner, but Gunk Engine Cleaner stuff works pretty good, especially if you do it on a hot day in the sun. Spray it on and let it sit for 15 minutes then use a stiff plastic brush and a tub of really hot water to loosen and much grime as possible, and hose it off.
Wish there was a good way to catch the oil and grime. Can't be good for the environment rinsing that stuff into the lawn or storm drain. Going to a professional steam rack is probably the most environmentally friendly plan. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:45 PM |
