JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
I have the pictured radio which was in my car when i bought it. I've not tested it yet but as it has no stickers or part / serial numbers i cannot get more info.
I believe (my electrical knowledge is pretty basic) it is a stereo unit and as there is a din plug on the rear i'm hoping to be able to run external inputs through it. If you look above the din socket there is a small connector hidden inside a round recess, what is this for? All help advice (apart from unhelpful/sarcastic) appreciated. ![]() ![]() |
smg914 |
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,979 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None ![]() ![]() |
It is a mono radio. If it were stereo, it would have the word "stereo" on the dial face.
The female plug on the right is probably for an amplifier which is not needed. And of course the hole on the left is for the antenna. The other opening you mention just above the female connection I believe is for the speaker connection. The lug terminal on the upper right would be the power connection and the one in the left would be the ground connection. |
Lo-Fi Version | Time is now: 16th July 2025 - 09:42 AM |
