Timing degrees and results and cautions...., Is 27 degrees it or can you deviate? |
second wind |
Jan 21 2018, 02:46 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there......my car just got back on the road due to a bad coil and it was tricky to find as it still sparked the plugs....just not under compression. During wrenching we altered the timing and it is at 33 degrees btdc now. Car starts great and has tons of low end.....kind of stops pulling at 5,000 rpm with slight knocking. Replaced seemingly healthy vacuum lines to distributor and high end improved a bit and some knocking sound lessened. What are your experiences with not being at 27 degrees and what are the risks? Thank you very much. BTW.....not driving car for months is depressing and now driving is really a blast!! No wonder we are here.
gg |
gereed75 |
Jan 21 2018, 08:06 PM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Not sure why you would want to run higher than specified. The specified advance is designed to optimize power for any set of engine design parameters (stroke, cam timing etc) advancing timing past the spec leads to higher internal cylinder pressures and corresponding higher stress on bearing and higher CHT’s and less power. There might be some gain for slightly advanced timing and higher octane than specified but not much.
Increased risk of knock, bearing wear, higher CHT’s and less power. Why bother? |
Lo-Fi Version | Time is now: 9th June 2024 - 07:32 PM |
