Cleaning the "inside" of heat exchangers |
Cazz |
Jan 21 2018, 05:12 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
Just bought a 73 914. Previous owner has resealed the engine. No noticeable oil leaks. Also the outside of the heat exchangers are very clean.
Problem: The inside of the heat exchangers have oil in them. When the engine gets hot tons of smoke comes bellowing out of the heat exchangers. You can actually hear the oil crackling and burning. Is there anyway to clean all of this oil out of the "inside" of the heat exchangers without taking them off the car or will this car always smoke with these on the car |
johnhora |
Jan 22 2018, 03:59 PM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
If you don't want to remove the HEs...then try first by taking the heater hoses off the HEs...then run a garden water hose inside of each HE and run water thru them to rinse the oil out....use some detergent in a spay bottle to help with the oil...since you're in NC and not CA the epa won't have any trouble with your run off....maybe worth a try?
mepstein |
Jan 22 2018, 04:20 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you don't want to remove the HEs...then try first by taking the heater hoses off the HEs...then run a garden water hose inside of each HE and run water thru them to rinse the oil out....use some detergent in a spay bottle to help with the oil...since you're in NC and not CA the epa won't have any trouble with your run off....maybe worth a try? That's what I would do if the oil in in the air box section. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:39 PM |
