Timing degrees and results and cautions...., Is 27 degrees it or can you deviate? |
second wind |
Jan 21 2018, 02:46 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there......my car just got back on the road due to a bad coil and it was tricky to find as it still sparked the plugs....just not under compression. During wrenching we altered the timing and it is at 33 degrees btdc now. Car starts great and has tons of low end.....kind of stops pulling at 5,000 rpm with slight knocking. Replaced seemingly healthy vacuum lines to distributor and high end improved a bit and some knocking sound lessened. What are your experiences with not being at 27 degrees and what are the risks? Thank you very much. BTW.....not driving car for months is depressing and now driving is really a blast!! No wonder we are here.
gg |
gothspeed |
Jan 23 2018, 10:23 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Does anyone run 'locked out' timing on their type 4? I have seen it done on many other car engine configurations. Many magnetos are 'locked out'. But I have not yet seen any threads or talk about it here on world.
brant |
Jan 23 2018, 03:40 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Does anyone run 'locked out' timing on their type 4? I have seen it done on many other car engine configurations. Many magnetos are 'locked out'. But I have not yet seen any threads or talk about it here on world. when you say "locked out" do you mean to lock the advance plates? We used to run a locked advance distributor on a type 4 race car Literally had a sheet metal screw locking it but you need advance and retard on a street car. on a full race car that only runs in a power band between 5,000-7,000 rpm you don't need anything but full advance. it would bog and run crappy at low rpm. starting isn't fun either |
Lo-Fi Version | Time is now: 1st June 2024 - 10:27 PM |
