Cleaning the "inside" of heat exchangers |
Cazz |
Jan 21 2018, 05:12 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
Just bought a 73 914. Previous owner has resealed the engine. No noticeable oil leaks. Also the outside of the heat exchangers are very clean.
Problem: The inside of the heat exchangers have oil in them. When the engine gets hot tons of smoke comes bellowing out of the heat exchangers. You can actually hear the oil crackling and burning. Is there anyway to clean all of this oil out of the "inside" of the heat exchangers without taking them off the car or will this car always smoke with these on the car |
johnhora |
Jan 24 2018, 09:56 AM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
vacca...not sure what you are asking...
but if you want to do this while the HEs are on the car... 1: remove the heater parts from the HE 2: You now have a BIG U (yellow) 3: take a garden hose and put in the HE at the red arrow 4: turn on the water.....water and oil will come out the HE at the green arrow (can use red or green in reverse) 5: use all safety measures and gear to not get wet or hurt |
VaccaRabite |
Jan 25 2018, 08:42 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
vacca...not sure what you are asking... but if you want to do this while the HEs are on the car... These things are famous for having the exhaust pipes crack inside the air jackets where you can't see them. So if you flood the air jacket and water comes out the exhaust pipe, that means you have a leak venting raw exhaust into your cabin. No a good thing! Zach |
Lo-Fi Version | Time is now: 9th June 2024 - 07:44 PM |
