Motor is tight when turning by hand |
swood |
Nov 6 2004, 10:14 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, I've finally cut the p-rods and am loading them in and adjusting the valves. Right now it's on TDC for #1. I notice that when I turn the flywheel, at some point in the rotation there is a little tightness for a few degrees, maybe a 1/4 turn or so. My jugs were opened to 96mm with new KB's and hastings rings. Could this be just the rings on one of the pistons when down low in the cylinder? I don't know how free a new motor is to turn. The crank turned smooth as silk before connecting the rods, p&c's etc.
My hands hurt from the teeth on the flywheel so any thoughts would be great. |
Jake Raby |
Nov 9 2004, 01:26 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
If the cylinder is honed correctly it will have no taper and will be round no matter where it is measured. Junk cylinders are not..
The widest point on the skirt is where to measure. Normally found toward the bottom of the skirt on a KB, but they vary.. The measurement you will see should be around 3.7785 Want you guys be glad when you can buy these parts with no guesswork and just drop them right in????? |
Lo-Fi Version | Time is now: 15th June 2024 - 07:27 PM |
