Can there be a rust free 914? |
cal44 |
Feb 2 2018, 08:35 AM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
There are so many used parts available for 914's it dawned on me the cars rot around the parts.
The one we have in currently has been taken care of by the original owner and it still has hell hole issues. Always garaged in central California the guy washed and waxed on a regular basis. With rain tray in place, the sides (opposite ends of rain tray) are open, the water pours in over the battery. That aspect is a poor design at best. Don't get me wrong, I'm hooked the 914 but the poor things are like open windows in a house during a rain storm, the wood floors will suffer. At times I read rust free 914 for sale. Is it possible to have an "original rust free 914"? |
burton73 |
Feb 4 2018, 11:29 AM
burton73 Group: Members Posts: 3,549 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Keep your 914 out of water as much as you can. --Keep your powder dry boys--
keep one's powder dry. Stay alert, be careful, as in Go ahead and take on the opposition, but keep your powder dry . This colloquial expression, which originally alluded to keeping gunpowder dry so that it would ignite, has been used figuratively since the 1800s but today is less common than take care What Rust Is In order to understand how rust works and spreads, you first have to understand what rust is. "Rust" is the common name for what is scientifically known as iron oxide, a form of corrosion that occurs when iron (or one of its alloys, such as steel) reacts with oxygen and there is water (or heavy air moisture) present. Other metals have oxidation processes as well, but they do so differently and the result is not commonly considered rust. Copper corrosion is green (and accounts for the color of the Statue of Liberty) while aluminum corrosion spreads extremely slowly. The Molecular Process of Spreading The process of metal corrosion is an electrochemical process. It happens on a molecular level as electrons transfer from iron molecules to the surrounding oxygen molecules, changing the makeup of the iron and turning it into rust. This is happening to iron all the time. In fact, it is impossible to find a piece of iron without at least some oxide present within it. However, the rate of rusting is usually slight and slow but is accelerated by water, especially if the water has a high concentration of electrolytes (substances in the water that help electrons move).This is why the presence of salt causes rust to spread more quickly. Spreading Rust does not spread through contact like a biological infection. Instead, the process of iron oxidization occurs independently based on the conditions surrounding a particular piece of metal. This means that if one part of the piece is exposed to water, oxygen, and electrolytes but the rust of the piece is kept clean and dry, the protected metal will not rest at the rate of the wet metal. Iron alloys will have different corrosion rates based on their makeup. Bob B |
Lo-Fi Version | Time is now: 8th June 2024 - 01:18 AM |
