> Craigslist 914 Mechanic, Is this person a member here?
1adam12
post Jan 13 2018, 06:29 PM
I've seen this ad on craigslist (Los Angeles) offering 914 help. Just wondering if this person Brian is a member here. Looking for some local help with my car but not going to spend $250 for a Porsche mechanic to just inspect it.
https://losangeles.craigslist.org/wst/cto/d...6416309419.html
I need someone to recheck my valve adjustment, timing, dizzy and to bring a working MPS. I'm pretty sure I've screwed all this up as my 1.7l won't turn over now.
cmxiv 74
post Feb 5 2018, 02:43 AM
Hi, Good you fixed your problems. My opinion about the subject... just saying, for the record: I called a CL add some months ago, a guy Brian (could be same guy or not, no clue, the add link you in your post is deleted)... He sounded knowledgeable about 914 carbed and such...well, based on a brief conversation... Long story short..for almost 1 month I tried to reach the guy, but anytime I called or text he replied that he was busy or he was in a rush, promised to call back , never did...I walked away...So reputably unknown mechanics with adds on Craigslist probably are not the way not fix our cars. While I put my car on the back burner (way to frustrating...) I'm still looking for someone in LA who can hep me tune/fix my double empi 40 carbed 1.7. So far, based on my experience and struggle nobody want to touch a single or double carbed 914. Good luck with your car.
1adam12   Craigslist 914 Mechanic   Jan 13 2018, 06:29 PM
mgphoto   Ok, lets start with your terminology? Turn over, s...   Jan 13 2018, 07:29 PM
1adam12   Ok, lets start with your terminology? Turn over, ...   Jan 13 2018, 07:45 PM
Mikey914   Sounds like you might get somefree advice as to we...   Jan 13 2018, 07:31 PM
Montreal914   If it was running before you pulled out the distri...   Jan 13 2018, 08:45 PM
1adam12   If it was running before you pulled out the distr...   Jan 13 2018, 08:55 PM
r_towle   You are near Los Angeles. Go find a local VW airco...   Jan 13 2018, 09:00 PM
914werke   Thank you Montreal914 and Mark for the support. I...   Jan 13 2018, 09:45 PM
Tom_T   Near-ish to you in OC, you can try either Bill Bre...   Jan 13 2018, 09:48 PM
thelogo   Ive seen the same add And it seems to good to be...   Jan 13 2018, 09:59 PM
Mueller   Ive seen the same add And it seems to good to b...   Jan 14 2018, 01:06 PM
thelogo   [quote name='thelogo' post='2567945' date='Jan 13...   Jan 14 2018, 01:26 PM
get off my lawn   How do you get to know someone well without mee...   Jan 18 2018, 06:00 PM
Tdskip   Do you feel comfortable with the idea of static ti...   Jan 13 2018, 10:55 PM
KELTY360   Have you called him to see if he's a member he...   Jan 13 2018, 11:19 PM
Andyrew   If that was on my local craigslist you can guarant...   Jan 14 2018, 01:35 AM
r_towle   The car is running a vw bus motor, so it’s fairl...   Jan 14 2018, 09:56 AM
76-914   Be sure that the molex plug at the Dist hasn't...   Jan 14 2018, 11:42 AM
914_teener   Maybe I can help you out. I'm in Glendora and...   Jan 14 2018, 01:00 PM
bdstone914   I have not heard of him before. I could suggest a...   Jan 14 2018, 11:01 PM
Larmo63   :agree: Bruce helped me out A LOT when I was try...   Jan 15 2018, 01:03 AM
bdstone914   Looking more at the ad I would probably not use wh...   Jan 15 2018, 07:30 AM
craig downs   I live in Eastvale which is close to you. I'm ...   Jan 15 2018, 12:02 PM
7TPorsh   What kind of points setup in the dizzy? Is it per...   Jan 16 2018, 10:46 AM
1adam12   Thanks to everyones input here, I really appreciat...   Jan 16 2018, 03:00 PM
snakemain   Odd coincidence with the "Oh Happy Day" ...   Jan 16 2018, 08:45 PM
nimblemotorsports   right off the bat, I'd say DO NOT use this guy...   Jan 17 2018, 07:32 PM
Front yard mechanic   right off the bat, I'd say DO NOT use this gu...   Jan 18 2018, 08:13 AM
1adam12   FINALLY! FINALLY! FINALLY! Got her ru...   Jan 18 2018, 03:07 PM
The Cabinetmaker   Sometimes its the simple things in life that give ...   Jan 18 2018, 03:37 PM
cmxiv 74   Hi, Good you fixed your problems. My opinion about...   Feb 5 2018, 02:43 AM
Lucky9146   Hi, Good you fixed your problems. My opinion abou...   Feb 5 2018, 09:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:44 PM
