| 1adam12 |
Jan 13 2018, 06:29 PM
Member ![]() ![]() Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
I've seen this ad on craigslist (Los Angeles) offering 914 help. Just wondering if this person Brian is a member here. Looking for some local help with my car but not going to spend $250 for a Porsche mechanic to just inspect it.
https://losangeles.craigslist.org/wst/cto/d...6416309419.html I need someone to recheck my valve adjustment, timing, dizzy and to bring a working MPS. I'm pretty sure I've screwed all this up as my 1.7l won't turn over now. |
| cmxiv 74 |
Feb 5 2018, 02:43 AM
Newbie ![]() Group: Members Posts: 11 Joined: 9-August 17 From: Los Angeles Member No.: 21,334 Region Association: Southern California |
Hi, Good you fixed your problems. My opinion about the subject... just saying, for the record: I called a CL add some months ago, a guy Brian (could be same guy or not, no clue, the add link you in your post is deleted)... He sounded knowledgeable about 914 carbed and such...well, based on a brief conversation... Long story short..for almost 1 month I tried to reach the guy, but anytime I called or text he replied that he was busy or he was in a rush, promised to call back , never did...I walked away...So reputably unknown mechanics with adds on Craigslist probably are not the way not fix our cars. While I put my car on the back burner (way to frustrating...) I'm still looking for someone in LA who can hep me tune/fix my double empi 40 carbed 1.7. So far, based on my experience and struggle nobody want to touch a single or double carbed 914. Good luck with your car.
| Lucky9146 |
Feb 5 2018, 09:34 AM
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,699 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California
Hi, Good you fixed your problems. My opinion about the subject... just saying, for the record: I called a CL add some months ago, a guy Brian (could be same guy or not, no clue, the add link you in your post is deleted)... He sounded knowledgeable about 914 carbed and such...well, based on a brief conversation... Long story short..for almost 1 month I tried to reach the guy, but anytime I called or text he replied that he was busy or he was in a rush, promised to call back , never did...I walked away...So reputably unknown mechanics with adds on Craigslist probably are not the way not fix our cars. While I put my car on the back burner (way to frustrating...) I'm still looking for someone in LA who can hep me tune/fix my double empi 40 carbed 1.7. So far, based on my experience and struggle nobody want to touch a single or double carbed 914. Good luck with your car. Have to agree that CL is probably not the best source for finding a capable person or shop to work on a double carbed 914. That said, I don't know anything at all about the availability of expertise in LA, but if you are willing to travel to San Diego there is, Black Forest Automotive. A friend of mine had his 914-6 conversion tuned there with great success. But better than that, this is the shop that has the engine guy who is involved with the 911's that are "Singer like" selling on BAT for well over 200k. Look harder in LA or reach out here to Keith914 a very smart guy who may be able to help. If not chat up Black Forest Porsche here in San Diego. www.blackforestautomotive.com/ They may be a bit pricey but your problem will be solved, I believe, and it just may be worth it. No affiliation what so ever with the shop just know of them. From someone who at times has also been a frustrated 914 owner. Best of luck! (IMG:style_emoticons/default/white914.jpg) |
1adam12 Craigslist 914 Mechanic Jan 13 2018, 06:29 PM
mgphoto Ok, lets start with your terminology?
Turn over, s... Jan 13 2018, 07:29 PM
1adam12
Turn over, ... Jan 13 2018, 07:45 PM
Mikey914 Sounds like you might get somefree advice as to we... Jan 13 2018, 07:31 PM
Montreal914 If it was running before you pulled out the distri... Jan 13 2018, 08:45 PM
1adam12
If it was running before you pulled out the distr... Jan 13 2018, 08:55 PM
r_towle You are near Los Angeles.
Go find a local VW airco... Jan 13 2018, 09:00 PM
914werke Thank you Montreal914 and Mark for the support. I... Jan 13 2018, 09:45 PM
Tom_T Near-ish to you in OC, you can try either Bill Bre... Jan 13 2018, 09:48 PM
thelogo Ive seen the same add
And it seems to good to be... Jan 13 2018, 09:59 PM
Mueller
And it seems to good to b... Jan 14 2018, 01:06 PM
thelogo
[quote name='thelogo' post='2567945' date='Jan 13... Jan 14 2018, 01:26 PM
get off my lawn
How do you get to know someone well without mee... Jan 18 2018, 06:00 PM
Tdskip Do you feel comfortable with the idea of static ti... Jan 13 2018, 10:55 PM
KELTY360 Have you called him to see if he's a member he... Jan 13 2018, 11:19 PM
Andyrew If that was on my local craigslist you can guarant... Jan 14 2018, 01:35 AM
r_towle The car is running a vw bus motor, so it’s fairl... Jan 14 2018, 09:56 AM
76-914 Be sure that the molex plug at the Dist hasn't... Jan 14 2018, 11:42 AM
914_teener Maybe I can help you out.
I'm in Glendora and... Jan 14 2018, 01:00 PM
bdstone914 I have not heard of him before. I could suggest a... Jan 14 2018, 11:01 PM
Larmo63 :agree:
Bruce helped me out A LOT when I was try... Jan 15 2018, 01:03 AM
bdstone914 Looking more at the ad I would probably not use wh... Jan 15 2018, 07:30 AM
craig downs I live in Eastvale which is close to you. I'm ... Jan 15 2018, 12:02 PM
7TPorsh What kind of points setup in the dizzy? Is it per... Jan 16 2018, 10:46 AM
1adam12 Thanks to everyones input here, I really appreciat... Jan 16 2018, 03:00 PM
snakemain Odd coincidence with the "Oh Happy Day" ... Jan 16 2018, 08:45 PM
nimblemotorsports right off the bat, I'd say DO NOT use this guy... Jan 17 2018, 07:32 PM
Front yard mechanic
right off the bat, I'd say DO NOT use this gu... Jan 18 2018, 08:13 AM
1adam12 FINALLY! FINALLY! FINALLY! Got her ru... Jan 18 2018, 03:07 PM
The Cabinetmaker Sometimes its the simple things in life that give ... Jan 18 2018, 03:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:40 PM |
