> 123Ignition Problem, No spark - Is it my wires?
clapeza
post Feb 5 2018, 08:23 AM
I've installed the 123Ignition distributor in my 1970 1.7 Djet, but I've got no spark. My car was running well enough before. I bought the Djet friendly distributor (4-R-V-IE) and a new Bosch Blue Coil during the group buy, but kept my (not so) old spark plug wires. When cranking, I get no attempt to start. I checked for spark by clipping my timing light lead on the #1 wire, but get no flash, suggesting no spark.
I installed the distributor per the instructions and the helpful hints from the group buy thread. Left the black wire off the coil to set the static timing. I saw the timing LED through one of the slots, as expected. I rotated it until it went off, then back until it just went on.
While rotating it, I got a mechanical solenoid sound ("BZZZzztt") from inside the distributor that lasted a second at most. No one has mentioned this previously, so I thought I would to make sure it's what everyone else has seen.
Connected the black wire to the coil, then attempted to crank it. All the usual noises are there for any attempted ignition, except no sounds like it's trying to fire. No catch, no backfire, etc.
My spark plug wires are Bosch Ultra-Premium 7mm Opti-Layer Copper Core. They're not that old, and are still in good shape. I've checked the boots and the connectors, making sure they're making good contact inside the cap. I know there was the option to buy new wires from 123Ignition, but I kept the old ones since they are in good shape; but are they not up to snuff for this distributor?
BeatNavy
post Feb 5 2018, 12:20 PM
You're sure the "buzzing" sound was inside the distributor and wasn't the fuel pump activating? I feel like I heard the fuel pump activate during this process, but I honestly can't explain why it would activate by turning the distributor. I can't remember all the conditions required for the fuel pump to run on D-Jet off hand. Maybe I'm making that up -- it's been a couple of months.
Seems to me like something simple may be out of place. I would verify that a) you've actually got the dizzy full inserted and the gears are engaging, and b) that the rotor and rotor cap are on correctly and tightly. You can do the former by moving the engine (e.g., using a drive wheel and blocking the other) to make sure rotor is actually moving. Check the latter to make sure the clips haven't been tweaked. You may have to bend them back so you get enough tension to keep the distributor cap on tightly.
clapeza
post Feb 5 2018, 01:19 PM
QUOTE(BeatNavy @ Feb 5 2018, 01:20 PM) *
Yep, I checked that it was fully seated and the rotor turns while turning the engine by hand or when cranking. The clips are properly seated and not tweaked.
I feel pretty certain the noise is coming from the distributor and not the fuel pump. As often as I heard the fuel pump energize while turning the key, I don't know that I've ever had my head in the engine compartment to hear it when it does. So that's something to investigate.
Yeah, I suspect there's something simple that's wrong, but I haven't been able to chase it down. Thanks for your suggestions. I'll keep looking.
- Lo-Fi Version Time is now: 9th July 2025 - 03:48 PM
