G lite, Not going off. |
malcolm2 |
Feb 3 2018, 02:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Took a 3 hour drive to Knoxville today. I watched the volt gauge. Seemed to be irratic. Hung at 11.4. But would jump to 13.5 for a short time them back to. 11.4. G lite was not on during the drive. After a short stop the re start is when the lite stayed on. Guage still at 11.4. I gotta get home.
Auto zone has a voltage reg. Is this a typical symptom of the easy to replace VR? |
malcolm2 |
Feb 5 2018, 05:32 PM
I have had this alternator off 2 times in the last 40k miles. I will not be rebuilding it. I will probably take it apart and see if there is anything obvious. Last time the pulley and shaft were moving in and out. Cause alot of clanking. The rebuilder did that repair for free and said he would not rebuild it again.
You are correct tho. It is one GIANT PITA. Having a 75 requires me to remove the exhaust on that side. Otherwise the unit will not come out. I can loosen it, but it won't come out. Hence my thoughts of a new style Higher Amp upgrade. So I hope to get more miles out of a good high quality, high tech ALT. Belt seems tight. I would guess 1/2 to 1" flex. Spoke, BTW I got your relay today. Installed it and it WORKS LIKE DESIGNED. Thanks. Did you say you could modify the Werhle brand that won't blink with low load? |
Spoke |
Feb 6 2018, 07:06 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Did you say you could modify the Werhle brand that won't blink with low load? I haven't done it but it should be possible. Most flashers are designed to sense the bulb current with a resistor. This is why they hyperflash when the current is lower when one bulb is out. LED-compatible flashers have this same resistor either shorted out or much higher resistance to sense really low currents. With the low cost of EP26 ($12-$16) not sure if it's worth digging into the Werhle flasher. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:48 AM |
