Velocity stack testing!, Been playing on the dyno again! |
Jake Raby |
Nov 9 2004, 04:29 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Yep,
Remember the posts about URY and his "too tall" stacks?? I decided to post the data from my latest engine combo as i try to find the perfect stack arrangement for it.. Guys wanting a cheaper, reliable TIV engine will love this one because it has a ton of torque and awesome smoothness. It does NOT have ported heads, so its almost 1,000.00 cheaper than some of its bigger brothers and makes torque very similar, but does not have the RPM range.. Ultimate daily drivin, short shiftin, 901 abusin power- plant.. Anyway, look at these plots and descriptions for this engine here http://www.shoptalkforums.com/viewtopic.php?t=80579 I plan on replicating this exact test on the next 10 engines I dyno and see how port work and cam changes effect the results. The results from this engine do not follow suite with my earlier findings, but almost all those tests were done on high revvin engines.... |
URY914 |
Nov 9 2004, 08:38 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
QUOTE(Jake Raby @ Nov 9 2004, 06:08 PM) Did you change your jetting after you changed the stacks?? No I didn't but I'll look and see what I'm running now and what sizes I have. Paul BTW, I was kidding about the science fair thing. We're going to do a compairson between fiberglass, wood and carbonfiber. We're going to make F/G and C/F the same size as a wooden paint stiring stick. We'll put a weight on them and see which one bends the most. Simple.(IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 08:01 AM |
