| Tdskip |
Feb 12 2018, 08:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning - just doing some planning here but it looks (to my undereducated eyes anyway) that the weld-in and bolt-in mounts are similar. Do people use the Patrick Motorsports one simply to avoid welding?
It looks like a bolt-in one would need holes drilled in the firewall to mount it? Thanks in advance for the schooling. |
| Steve |
Feb 12 2018, 08:37 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,133 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Correct. All the mounts are welded in, but the cross bar motor mount that uses the stock 914-4 early motor mounts. Also known as the “quick six”
MSDS used to make the quick six mount. I ran it for over 10 years with no problems. The quick six only works with headers. I switched to the Rich Johnson mount when I switched to heat exchangers. The firewall mount moves the weight forward compared to the quick six for better overall weight distribution |
Tdskip Could someone take me to school on the merits of a bolt-on vs welding 914/6 engne mount? Feb 12 2018, 08:11 AM
Good morning - just doing some planning here but ... Feb 12 2018, 08:23 AM
worn
Good morning - just doing some planning here but ... Feb 12 2018, 08:26 AM
Tdskip Good morning - so when Patrick Motorsports says bo... Feb 12 2018, 08:26 AM
Good morning - so when Patrick Motorsports says b... Feb 12 2018, 08:33 AM
Tdskip
My mistake. I looked at their site and they do ha... Feb 12 2018, 08:39 AM
Steve
Good morning - so when Patrick Motorsports says ... Feb 12 2018, 08:39 AM
jd74914
[quote name='mepstein' post='2578129' date='Feb 1... Feb 12 2018, 08:43 AM
JOEPROPER
[quote name='mepstein' post='2578129' date='Feb ... Feb 12 2018, 08:59 AM
billh1963
Good morning - so when Patrick Motorsports says ... Feb 12 2018, 07:49 PM
Tdskip
Correct. All the mounts are welded in, but the c... Feb 12 2018, 08:40 AM
Cairo94507 I think Naro914 has a great mount. For me, if you... Feb 12 2018, 09:01 AM
patssle Uhhhh - the PMS bolt in mount does NOT need to be ... Feb 12 2018, 09:11 AM
sithot The setups appear similar. Why is the NaroEscape ... Feb 12 2018, 09:19 AM
naro914
The setups appear similar. Why is the NaroEscape... Feb 13 2018, 07:10 AM
GeorgeRud I believe that mb911 (Ben) is working on replicati... Feb 12 2018, 09:28 AM
I believe that mb911 (Ben) is working on replicat... Feb 12 2018, 09:33 AM
JmuRiz It just is :D It's basically like an improved... Feb 12 2018, 09:32 AM
Larmo63 I used the Patrick Motorsports weld in mount. I pr... Feb 12 2018, 03:33 PM
Tdskip
I used the Patrick Motorsports weld in mount. I p... Feb 12 2018, 08:19 PM
Larmo63 Yes, it is two layers thick there...... Feb 13 2018, 12:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 11:18 AM |
