WTB: Shift rod for 6 conversion, side shift trans, Got one sitting around? |
koozy |
Feb 11 2018, 10:38 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I'm looking for a shift rod for 6 conversion, side shift trans. Does anyone have one sitting around?
Thanks, Mike |
deemsriddle |
Feb 12 2018, 07:35 AM
Newbie Group: Members Posts: 15 Joined: 1-January 17 From: Ringgold GA Member No.: 20,717 Region Association: South East States |
I am building a 914/4. I was pressing the pin out of my old shifter to replace the bushing in the U-joint and it exploded. No kidding. I probably should had shot it with penetrating oil, but there was no sign of corrosion. Save yourself a lot of grief and buy new from Tangerine racing. It looks to be a superior product anyhow. The gear shift linkage in 914s were horrible in the first place.
bdstone914 |
Feb 12 2018, 01:06 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am building a 914/4. I was pressing the pin out of my old shifter to replace the bushing in the U-joint and it exploded. No kidding. I probably should had shot it with penetrating oil, but there was no sign of corrosion. Save yourself a lot of grief and buy new from Tangerine racing. It looks to be a superior product anyhow. The gear shift linkage in 914s were horrible in the first place. The couplers are fragile and will no take much pressure without breaking. I had a shift rod with a stuck pin, Heated it with a torch do soften and dig out the bushings. Then heated with a Map gas torch trying to direct to heat on the pin and not the aluminum coupler. With the bushings out you can insert a socket through the coupler to contacting the square block. With it supported there you can use a vise or BFH and punch to loosen the pin. Worked it back and forth until the pin cam out. Nice billet couplers are made fir 911 which work in a 914. https://www.pelicanparts.com/cgi-bin/ksearc...r=STOMSKI-SR010 |
Lo-Fi Version | Time is now: 11th June 2024 - 04:13 AM |
