> Could someone take me to school on the merits of a bolt-on vs welding 914/6 engne mount?
Tdskip
post Feb 12 2018, 08:11 AM
Good morning - just doing some planning here but it looks (to my undereducated eyes anyway) that the weld-in and bolt-in mounts are similar. Do people use the Patrick Motorsports one simply to avoid welding?
It looks like a bolt-in one would need holes drilled in the firewall to mount it?
Thanks in advance for the schooling.
Larmo63
post Feb 12 2018, 03:33 PM
I used the Patrick Motorsports weld in mount. I pre mounted it with a big f---king nut and bolt at it's weld in location, then welded it. You can't see the BF bolt head in this shot, but it is what is holding it to the lower firewall. After welding, I just left them in for insurance.
Suspenders AND a belt.Attached Image
Tdskip
post Feb 12 2018, 08:19 PM
QUOTE(Larmo63 @ Feb 12 2018, 03:33 PM) *
Thank you for the picture. Did you drill through the firewall so you could mount the assembly and hold it in place prior to welding?
Tdskip   Could someone take me to school on the merits of a bolt-on vs welding 914/6 engne mount?   Feb 12 2018, 08:11 AM
mepstein   Good morning - just doing some planning here but ...   Feb 12 2018, 08:23 AM
worn   Good morning - just doing some planning here but ...   Feb 12 2018, 08:26 AM
Tdskip   Good morning - so when Patrick Motorsports says bo...   Feb 12 2018, 08:26 AM
mepstein   Good morning - so when Patrick Motorsports says b...   Feb 12 2018, 08:33 AM
Tdskip   My mistake. I looked at their site and they do ha...   Feb 12 2018, 08:39 AM
Steve   Good morning - so when Patrick Motorsports says ...   Feb 12 2018, 08:39 AM
jd74914   [quote name='mepstein' post='2578129' date='Feb 1...   Feb 12 2018, 08:43 AM
JOEPROPER   [quote name='mepstein' post='2578129' date='Feb ...   Feb 12 2018, 08:59 AM
billh1963   Good morning - so when Patrick Motorsports says ...   Feb 12 2018, 07:49 PM
Steve   Correct. All the mounts are welded in, but the cr...   Feb 12 2018, 08:37 AM
Tdskip   Correct. All the mounts are welded in, but the c...   Feb 12 2018, 08:40 AM
Cairo94507   I think Naro914 has a great mount. For me, if you...   Feb 12 2018, 09:01 AM
patssle   Uhhhh - the PMS bolt in mount does NOT need to be ...   Feb 12 2018, 09:11 AM
sithot   The setups appear similar. Why is the NaroEscape ...   Feb 12 2018, 09:19 AM
naro914   The setups appear similar. Why is the NaroEscape...   Feb 13 2018, 07:10 AM
GeorgeRud   I believe that mb911 (Ben) is working on replicati...   Feb 12 2018, 09:28 AM
mepstein   I believe that mb911 (Ben) is working on replicat...   Feb 12 2018, 09:33 AM
JmuRiz   It just is :D It's basically like an improved...   Feb 12 2018, 09:32 AM
Larmo63   I used the Patrick Motorsports weld in mount. I pr...   Feb 12 2018, 03:33 PM
Tdskip   I used the Patrick Motorsports weld in mount. I p...   Feb 12 2018, 08:19 PM
Larmo63   Yes, it is two layers thick there......   Feb 13 2018, 12:42 AM
- Lo-Fi Version Time is now: 25th November 2026 - 11:18 AM
