mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
Found a set of heads locally on CL. He claims they came off a running engine. Any advice on what to ask, or obvious or hidden gotchas? Or is it pretty unavoidable that you're taking a roll of the dice?
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Rolling the dice with out disassembly. Look for cracks around the spark plug hole and check around valve seat for loose material. Use steel ruler to check deck for straightness. Check valve stems for wear.
Lo-Fi Version | Time is now: 13th June 2024 - 10:38 PM |
