> Assistance with Restoring 73 Wiring Harness
doug_b_928
post Jan 31 2018, 03:55 PM
My main Winter project is to 'restore' the wiring harness on my 73. I admit that of all the jobs involved in restoring this car, this is the one that creates the most anxiety in me. I took it out of it's container last winter, spread it out on the floor, and promptly proceeded to put it back in the container. But, the time has come to conquer this thing. I have 4 rolls of wire tape that cost more to ship to me than the tape itself, and I think everything I need to do the job. I have pieces of a 74 harness (which I'm aware is not the same) and have already used one of the correct connectors from it for one of the license plate light connectors. Overall, I think the harness could be a lot worse, but there are some areas where POs have made some modifications/fixes and I'm not sure what they've done and why. I'll be asking for assistance from the wiring gurus in the thread as I work my way through. I have the wiring diagram from Jeff Bowlsby's website, a multimeter, PowerProbe3, and cleaning supplies. I'm removing all the tape, inspecting, cleaning, and then installing new tape. I'm just going to clean and inspect the rubber covered sheaths as they seem to be tight around the wires and it seems unlikely that there is anything wrong underneath them (on the upside, everything that ever worked on the car during my ownership, which wasn't everything that was supposed to, still did right before I removed the harness).
Okay, so with that introduction, my first questions. Starting at the back, I've worked my way through the license plate wires, to the trunk light wires, and I'm currently looking at the fuel pump wires. My car had vapor lock, so the fuel pump was relocated to the front of the car. The mechanic just cut the wires, left the ground wire dangling, and spliced in a positive wire which he ran through the firewall (poking a hole; no grommet), under the carpet and through a hole in the front firewall, where he then spliced in the connector and grounded to a screw he added to the front firewall. Here's a pic of the wires:
Because of the vapor lock issue, I'm thinking I should put my new pump in the front where the old one was (by the steering rack). I'm thinking of getting the NAPA Bosch fuel pump (N69133). From what I can tell looking at the wiring diagram, and I could be reading it wrong, the power wire goes to the 'regulator/relay plate). If it's source was at the fuse box under the dash I'd splice into the wire up there and put the original connector back on the wires in the engine bay (in case I ever wanted to put an original style in its original spot. If I'm correct about the wiring diagram, then, with my limited knowledge, I guess I have to run the power wire on the outside of the sheath (but at least it will be inside the new 914 rubber snorkel) and up to the fuel pump in the front? Is there any point in running the ground wire that way too, or would you just ground it to a screw on the car as it was before?
Also, in the pic above there is a green wire that looks like it had a connector on it at one time. Does anyone know what that was for? When I look at the 73 diagram it only shows the black with red dots and the ground for the fuel pump. On the diagram it shows the, IIRC, 'fan blower motor' having a green wire. However, if that's referring to the blower motor for the heater, I think the wires and connector below were for that (note no green wire).
So, to summarize, what's the best approach for the fuel pump wiring, and what is that green wire for?
doug_b_928
post Feb 14 2018, 01:19 PM
Exactly, so I figure I'll just make up a single ground wire with a female spade to connect to the appropriate ground at the main harness and with one of those little connectors with a hole for the screw at the other end of the wire (my car didn't have the center console gauges). Here's the image from Jeff's page. It's not the same schematic in terms of wire color as for our 73s, and on our schematic the black with blue is coming back from a double wire on the male spade in the insulator for the centre console.
I checked Jeff's page re the intermittent relay wiring and I don't think that's it. There should have been a brown with black lead for that harness and there's no relay socket on it.
doug_b_928   Assistance with Restoring 73 Wiring Harness   Jan 31 2018, 03:55 PM
dr914@autoatlanta.com   cannot tell much from the pics but if it is a gree...   Jan 31 2018, 05:11 PM
simonjb   As an aside, you can buy those connectors from Bug...   Jan 31 2018, 05:45 PM
bbrock   cannot tell much from the pics but if it is a gre...   Jan 31 2018, 05:55 PM
earossi   There is a guy over on the Pelican Engine Rebuildi...   Jan 31 2018, 06:15 PM
mepstein   There is a guy over on the Pelican Engine Rebuild...   Jan 31 2018, 06:21 PM
earossi   There is a guy over on the Pelican Engine Rebuil...   Jan 31 2018, 08:23 PM
mepstein   [quote name='mepstein' post='2573750' date='Jan 3...   Jan 31 2018, 08:49 PM
earossi   [quote name='mepstein' post='2573750' date='Jan ...   Feb 3 2018, 04:03 PM
porschetub   Dennis isn't doing full 914 looms or he told m...   Feb 3 2018, 11:54 PM
Jeff Bowlsby   When relocating the FP to the front note that the ...   Jan 31 2018, 06:20 PM
malcolm2   Hope I am not too late. But I bought one of these...   Jan 31 2018, 06:27 PM
doug_b_928   Wow! Thank you to all of you for your helpful...   Jan 31 2018, 06:49 PM
bbrock   Brent, I think I'll have to study your postin...   Jan 31 2018, 06:59 PM
gothspeed   I am just about completed bringing my 73' harn...   Jan 31 2018, 06:59 PM
doug_b_928   So, using my spare harness pieces, I found the mat...   Feb 3 2018, 12:47 PM
Dave_Darling   A coat-hanger will poke through the snorkel. If y...   Feb 3 2018, 01:29 PM
bbrock   A coat-hanger will poke through the snorkel. If ...   Feb 3 2018, 02:27 PM
Jeff Bowlsby   Umm... The 1975-76 schematic indicates that the F...   Feb 3 2018, 02:47 PM
doug_b_928   Hmmm...So you're suggesting to pull the FP wir...   Feb 3 2018, 03:17 PM
bbrock   Hmmm...So you're suggesting to pull the FP wi...   Feb 3 2018, 03:22 PM
doug_b_928   Awesome Brent, thanks!   Feb 3 2018, 03:24 PM
doug_b_928   Until today I haven't had any time for this pr...   Feb 11 2018, 12:38 PM
bbrock   I haven't had to remove that one yet, but I be...   Feb 11 2018, 02:04 PM
Jeff Bowlsby   Its a female hollow tube terminal extractor. I ha...   Feb 11 2018, 02:29 PM
doug_b_928   Thanks guys. I was able to clean the connectors w...   Feb 11 2018, 04:39 PM
doug_b_928   @ Brent...Yes, they are from a label maker. I bou...   Feb 11 2018, 04:43 PM
doug_b_928   update: I see the unknown ground goes to the grou...   Feb 11 2018, 05:05 PM
Jeff Bowlsby   See wire 63 on the second page of the schematic. ...   Feb 11 2018, 07:01 PM
doug_b_928   Got it. Thanks Jeff! Looks like I'm th...   Feb 11 2018, 07:17 PM
914_teener   Got it. Thanks Jeff! Looks like I'm t...   Feb 11 2018, 11:06 PM
Dave_Darling   Black to the single terminal on the left. Brown t...   Feb 11 2018, 10:35 PM
doug_b_928   Thanks guys. Now I just need to find some of thos...   Feb 12 2018, 08:30 AM
bbrock   Thanks guys. Now I just need to find some of tho...   Feb 12 2018, 09:38 AM
doug_b_928   Thanks very much Brent. Do you know how to identi...   Feb 12 2018, 09:44 AM
bbrock   Thanks very much Brent. Do you know how to ident...   Feb 12 2018, 10:04 AM
gothspeed   The white striped ground wire comes from the drive...   Feb 12 2018, 10:04 AM
doug_b_928   Awesome, thanks!   Feb 12 2018, 01:16 PM
doug_b_928   Thanks to Brent I'll be ordering new connector...   Feb 13 2018, 09:25 PM
doug_b_928   Another quicker question: I think my car has the ...   Feb 13 2018, 09:54 PM
bbrock   IIRC, there is only a positive wire to the heater ...   Feb 14 2018, 12:05 AM
doug_b_928   Thanks as always, Brent. I appreciate you checkin...   Feb 14 2018, 09:05 AM
bbrock   Just looked at my harness and confirmed only one w...   Feb 14 2018, 09:30 AM
doug_b_928   Thanks, Brent. That also gives me a sense of how ...   Feb 14 2018, 09:53 AM
bbrock   Thanks, Brent. That also gives me a sense of how...   Feb 14 2018, 10:05 AM
bbrock   Ah! I just looked at the schematic and it loo...   Feb 14 2018, 12:50 PM
doug_b_928   Exactly, so I figure I'll just make up a singl...   Feb 14 2018, 01:19 PM
bbrock   Exactly, so I figure I'll just make up a sing...   Feb 14 2018, 06:12 PM
doug_b_928   Brent, that was an awesome tip re digikey and than...   Feb 17 2018, 09:29 AM
doug_b_928   Upon further investigation, things make a bit more...   Feb 17 2018, 12:27 PM
doug_b_928   Today's question: I think I've figured out...   Feb 18 2018, 10:59 AM
bbrock   Today's question: I think I've figured ou...   Feb 18 2018, 01:35 PM
gothspeed   Today's question: I think I've figured ou...   Feb 21 2018, 06:53 PM
Jeff Bowlsby   Fellas, its a circuit. From the power wire, throu...   Feb 18 2018, 04:06 PM
doug_b_928   Makes sense, thanks Jeff! PS. Does the mystery...   Feb 18 2018, 04:12 PM
Jeff Bowlsby   Don't know about the mystery harness. It may ...   Feb 18 2018, 04:18 PM
doug_b_928   Perfect, thanks Jeff!   Feb 18 2018, 04:21 PM
doug_b_928   My extremely limited knowledge of electronics cont...   Feb 21 2018, 08:06 AM
doug_b_928   Hoping someone will chime in about my previous pos...   Feb 21 2018, 06:36 PM
doug_b_928   I just searched some old pictures and it appears t...   Feb 21 2018, 06:46 PM
bbrock   I just searched some old pictures and it appears ...   Feb 21 2018, 07:45 PM
doug_b_928   Thanks very much Brent. Yeah, after all of this I...   Feb 23 2018, 07:44 PM
Jeff Bowlsby   If my memory is right the radio clips to Fuse #7 b...   Feb 23 2018, 08:05 PM
bbrock   3. A PO had installed an electric motor for the W...   Feb 23 2018, 11:49 PM
doug_b_928   Did a little searching and see that there was not ...   Feb 23 2018, 07:58 PM
doug_b_928   Thanks very much as always Jeff. I'll await y...   Feb 23 2018, 08:41 PM
Jeff Bowlsby   I know I have seen a harness with the radio at fus...   Feb 23 2018, 08:56 PM
doug_b_928   Thanks again Jeff! As an update, here's a...   Feb 23 2018, 09:01 PM
Jeff Bowlsby   Looks good. Hope you see now why I don't reco...   Feb 23 2018, 09:44 PM
doug_b_928   Thanks Jeff. So to make sure, no fire issues with...   Feb 23 2018, 09:49 PM
Jeff Bowlsby   I would not label them permanently, but I see no h...   Feb 23 2018, 10:10 PM
doug_b_928   Excellent, thanks Jeff. I'm leaving them for ...   Feb 23 2018, 10:16 PM
doug_b_928   Thanks for WW fluid system explanation, Brent. Do...   Feb 24 2018, 05:46 AM
doug_b_928   Update: I’ve added a couple pieces of wire (loo...   Feb 24 2018, 10:05 AM
doug_b_928   Technical question: the small black with blue wir...   Feb 24 2018, 02:35 PM
doug_b_928   Winter job done (with the exceptions of needing to...   Feb 25 2018, 10:19 PM
bbrock   :trophy: :cheer:   Feb 25 2018, 11:18 PM
doug_b_928   Thanks Brent. There are two questions that I forg...   Feb 26 2018, 08:47 AM
doug_b_928   Update re testing a diode: I found this youtube v...   Feb 26 2018, 10:19 AM
- Lo-Fi Version Time is now: 17th July 2025 - 06:23 AM
