Do Boxster calipers fit factory 16" Fuchs wheels, Some help please |
burton73 |
Feb 14 2018, 09:58 AM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Do the Boxster calipers fit factory Fuchs wheels. And do they need to be 16 in wheels.
I am putting Boxster Calipers on my V8 car and I want to know that the 16 Fuchs factory wheels in 16 inches will fit with 7 inch (911) and 8 inch( 951) wheels, Or 8 in (911) Thanks as always for the help. Bob B (IMG:style_emoticons/default/pray.gif) |
mepstein |
Feb 14 2018, 06:05 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
From what I’ve read on pelican, a lot of repro Fuchs don’t fit due to different inner dimensions than real Fuchs. The cast wheels require more material for the same strength and interfere with the larger calipers.
mmascari |
Feb 14 2018, 06:12 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
From what I’ve read on pelican, a lot of repro Fuchs don’t fit due to different inner dimensions than real Fuchs. The cast wheels require more material for the same strength and interfere with the larger calipers. I just sold a pair of Euromeisters in the classifieds because they didn't fit on the inside. The caliper rubbed and would have required a spacer. This was on the rear with Boxster non-S calipers. I have Boxster calipers on both front and rear. I thought about a small spacer but with a narrow body the offset would have brought the tire even further out towards the fender and would have never fit. |
Mitox |
Feb 14 2018, 06:20 PM
Member Group: Members Posts: 399 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
From what I’ve read on pelican, a lot of repro Fuchs don’t fit due to different inner dimensions than real Fuchs. The cast wheels require more material for the same strength and interfere with the larger calipers. I just sold a pair of Euromeisters in the classifieds because they didn't fit on the inside. The caliper rubbed and would have required a spacer. This was on the rear with Boxster non-S calipers. I have Boxster calipers on both front and rear. I thought about a small spacer but with a narrow body the offset would have brought the tire even further out towards the fender and would have never fit. If I understand your situation correctly, it seems that the interference was at the inner section of ID that ramps down to a smaller ID. The caliper must have initially fit into the ID. Is this correct? I'm asking, because I want to make my Euromeister work in my flared fenders. Thanks |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:30 AM |
