Stud specs help... |
MikeM |
Feb 15 2018, 11:23 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
I have a 73 2.0 liter that has been converted to carbs. I'm using a phenolic spacer under the intake manifolds to stop heat from cooking the carbs. Problem is that the studs that attach the intake to the heads are now too short and the nut only holds by a thread or 2. Does any know what I can use for a longer stud? Or maybe someone knows the specs of the stud? Is this a good idea? Will the old studs come out of the head? Thanks, Mike |
type2man |
Feb 15 2018, 01:53 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I wouldnt add the spacers, especially where you live. You want the manifold to heat up quickly in colder climates. Just install the thick paper gaskets. You won't harm anything
MikeM |
Feb 15 2018, 02:35 PM
I wouldnt add the spacers, especially where you live. You want the manifold to heat up quickly in colder climates. Just install the thick paper gaskets. You won't harm anything When I bought the car there were no spacers. After shutdown the carbs got so hot that the fuel would boil. Added the spacers and problem solved. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:24 AM |
