Stud specs help... |
MikeM |
Feb 15 2018, 11:23 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
I have a 73 2.0 liter that has been converted to carbs. I'm using a phenolic spacer under the intake manifolds to stop heat from cooking the carbs. Problem is that the studs that attach the intake to the heads are now too short and the nut only holds by a thread or 2. Does any know what I can use for a longer stud? Or maybe someone knows the specs of the stud? Is this a good idea? Will the old studs come out of the head? Thanks, Mike |
rhodyguy |
Feb 15 2018, 03:04 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
around 1/4". that's buying you some room and might allow retaining the phenolics. what are you using for washers?
MikeM |
Feb 15 2018, 03:15 PM
sithot |
Feb 15 2018, 03:35 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
around 1/4". that's buying you some room and might allow retaining the phenolics. what are you using for washers? I'm not using any washers!! No room!! You need a thin washer. 8mm that will fit under the nut. PVT nuts are good if you're scared of vibration but I've never had an issue with a nylon lock nut. I use these on velocity stacks for extra "grip". https://www.belmetric.com/stainless-high-type-c-3_752_1481/ |
MikeM |
Feb 15 2018, 03:44 PM
around 1/4". that's buying you some room and might allow retaining the phenolics. what are you using for washers? I'm not using any washers!! No room!! You need a thin washer. 8mm that will fit under the nut. PVT nuts are good if you're scared of vibration but I've never had an issue with a nylon lock nut. I use these on velocity stacks for extra "grip". https://www.belmetric.com/stainless-high-type-c-3_752_1481/ I'm using the nylon nuts and they don't vibrate loose. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:16 AM |
