Lift |
Lift |
Cracker |
Feb 18 2018, 09:39 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Thoughts, experiences, frequency of use, etc. If you have pictures of your set-up in general; decisions you wish you had made; decisions you were thankful you DID make - all would be helpful! I have plenty of ceiling height; do I need to spend big bucks for infrequent use (mostly as a storage device)? The lift will need to be functional for teener engine drops...suffice to say, it has to be a two-post.
Tony |
jmitro |
Feb 18 2018, 09:56 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath.
I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 Attached thumbnail(s) |
mepstein |
Feb 18 2018, 10:50 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath. I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 We often have to jack up a low car to slide the arm in and then use some spacers under the pad so it doesn't hit the rockers. |
cary |
Feb 18 2018, 11:15 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath. I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 We often have to jack up a low car to slide the arm in and then use some spacers under the pad so it doesn't hit the rockers. What Mark said. On both items. I have a box of 3*3 MDX pieces to use a spacers. I have a 10K Bend Pak Asymmetrical as a primary. We're planning on a 7k and 2 4 posts in the next upgrade. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:16 PM |
