Temperature readings |
JFG |
Feb 18 2018, 08:32 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I have a multi gauge with fuel on the bottom and temperature on top.
The temp gauge does not move. Is this reading taken from the cht or oil switch? I'm running carbs. A po removed all engine contents including wiring so I'm working from scratch. The oil switch is new and works regarding the pressure light. The cht is as was on the engine when I bought it and unknown working order. |
JFG |
Feb 18 2018, 11:43 AM
Thanks for the info.
I know where the temp sender should be now you describe it. What is the cht for? Fuel injection only? |
Lo-Fi Version | Time is now: 9th June 2024 - 01:10 AM |
