Lift |
Lift |
Cracker |
Feb 18 2018, 09:39 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Thoughts, experiences, frequency of use, etc. If you have pictures of your set-up in general; decisions you wish you had made; decisions you were thankful you DID make - all would be helpful! I have plenty of ceiling height; do I need to spend big bucks for infrequent use (mostly as a storage device)? The lift will need to be functional for teener engine drops...suffice to say, it has to be a two-post.
Tony |
jhynesrockmtn |
Feb 18 2018, 03:43 PM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I'm lucky to have a shop behind the house. I built it with 2 lifts in mind. The two post for mostly work although it is used for storage as well. I can fit a 911 under the car above when needed. I get the 996 on by driving onto some plywood pieces I cut out. Only takes 1/2 inch of lift to get the arms under it. Pulling the brakes off of the race car for rebuilding and will be pulling the engine in the next couple of weeks. I bought mine locally and had them do the install.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:22 PM |
