All this talk about jack stands..., what's the best way to keep it up? |
djm914-6 |
Nov 9 2004, 03:04 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
and get your minds out of the gutter. (IMG:style_emoticons/default/biggrin.gif)
I like JPs boxes but I don't have enough room nor is my floor overly level. I want to get the car up as high as possible and be able to work on various areas. Ideas? |
J P Stein |
Nov 10 2004, 01:15 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
QUOTE(Rhodes71/914 @ Nov 10 2004, 10:36 AM) JP I like that, where did you get the castor wheels?, Does the car roll around easy that way? I assume the wheels are strong enough. Harbor Freight (where else do CSOBs shop?) for the swivel casters. I can push it around by myself but 2 guys are better for control.....control is gud (IMG:style_emoticons/default/biggrin.gif) I have an 18" lift floor jack. I jack up one end bout 12 " & block it....then move to the other end & do the same. I then lower the jack & put blocks on the jack cup. ....up another 8-12 inches ...bout that time the boxes go in sideways. More blocks on the jack & up to the full height & the boxes go in upright. By myself, it takes 30-40 minutes....ahlf the time with help....a lift would be gud. I get 34 inches under the rear trunk bulkhead to pull the motor.....which is the only time I take it that high. Last winter it went up "only" this far. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 04:35 AM |
