How Old is Too Old for Tires? NPC, For a New Tire Sitting in the Garage |
andys |
Feb 14 2018, 12:08 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
About 1 1/2 years ago, slight collision repair on my daughters car, they mounted a non-matching tire. I pointed out their mistake, and they willingly mounted a matching tire. So when I bring the car home and open the trunk, there is the unmounted mismatched tire. I store it in the garage, unwrapped.
So now, my wife's 2010 Camry is in need of tires, coincidentally the same size as the NOS tire in the garage. Since that specific tire is still available, do I consider buying three new, and use the other to make up the set? What's the conventional wisdom? Worth the risk? Thanks, Andys |
Unobtanium-inc |
Feb 14 2018, 12:41 PM
Advanced Member Group: Members Posts: 2,213 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
My rule of thumb is anything under 3-4 years is probably good. I just changed out the tires on my 356, they had perfect tread but at 6 years old they had aged out. The tire guy thought I was crazy. But I always think about this guy, who was driving his Convertible D on old tires, they looked fine, until they didn't....
Attached image(s) |
thelogo |
Feb 14 2018, 06:56 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
My rule of thumb is anything under 3-4 years is probably good. I just changed out the tires on my 356, they had perfect tread but at 6 years old they had aged out. The tire guy thought I was crazy. But I always think about this guy, who was driving his Convertible D on old tires, they looked fine, until they didn't.... Let this be a lesson If you even think the tire needs replaceing then do it Tire is dirt cheap compared to the tens of thousands of dollars in body damage it will cause if it fails at speed. |
thelogo |
Feb 19 2018, 08:38 PM
My rule of thumb is anything under 3-4 years is probably good. I just changed out the tires on my 356, they had perfect tread but at 6 years old they had aged out. The tire guy thought I was crazy. But I always think about this guy, who was driving his Convertible D on old tires, they looked fine, until they didn't.... Let this be a lesson If you even think the tire needs replaceing then do it Tire is dirt cheap compared to the tens of thousands of dollars in body damage it will cause if it fails at speed. Just did my tires they were 17 years old Got some nice coopers for 412 bucks |
Lo-Fi Version | Time is now: 7th June 2024 - 05:42 PM |
