> Twin plug /4, ROI?
r_towle
post Feb 17 2018, 04:13 PM
Custom Member
Has anyone done testing to understand the Net difference between single and twin plug on a /4?
gereed75
post Feb 20 2018, 10:09 AM
Aha, great to hear from some one that’s been there done that. Thanks Bill.
The comments are right in line with what you see in the aircraft world where your engine is fairly well instrumented - a CHT and an EGT on each cylinder and the ability to turn one set of plugs on or off. Twin plugging enables less advanced timing while still getting complete burn, less advance means lower combustion peak pressures, lower peak pressures mean lower CHT’s and more torque ( the piston is not fighting an early combustion event while still traveling up towards TDC) and there is better combustion even in the shorter time available because of the two flame fronts.
How much better will certainly depend on lots of variables, but the more compression and the bigger the chamber the more advantage to be gained.
Worth it on a small, low compression four?? Dunno but More worth it on a bigger high compression motor, just as Bill found out.
BTW, awesome build thread linked and very informative info from Jake, that guy knows his shit! Miss him around here
r_towle   Twin plug /4   Feb 17 2018, 04:13 PM
mepstein   A twin plug doesn't make power in it's sel...   Feb 17 2018, 04:25 PM
ablesnead   I had one of the first ones years ago ....used a d...   Feb 17 2018, 04:38 PM
Mueller   Good question, i know on aircraft engines you can ...   Feb 17 2018, 04:39 PM
buz914   And aircraft engines are low compression, air cool...   Feb 17 2018, 07:11 PM
Mueller   And aircraft engines are low compression, air coo...   Feb 17 2018, 07:53 PM
Elliot Cannon   These guys rebuilt my heads for me. They can conv...   Feb 17 2018, 07:08 PM
Mueller   Microsquirt seems the easiest for twin plugging no...   Feb 17 2018, 07:51 PM
gms   The 914/4 combustion chamber is a modified wedge s...   Feb 18 2018, 09:23 AM
peteyd   Here is a build thread of a 2.8L twin plug http:/...   Feb 18 2018, 01:23 PM
Krieger   Sounds like one more place for the heads to crack ...   Feb 18 2018, 01:33 PM
gereed75   Agree with Glenn. The 911 benefits because of comb...   Feb 18 2018, 01:34 PM
peteyd   I have always been interested in a twin plugged en...   Feb 18 2018, 01:42 PM
914werke   The 914/4 combustion chamber is a modified wedge ...   Feb 18 2018, 05:05 PM
horizontally-opposed   European Car (RIP), maybe when it was still VW...   Feb 18 2018, 05:28 PM
914werke   European Car (RIP), maybe when it was still VW...   Feb 18 2018, 07:11 PM
r_towle   So, lots of cool responses. I am curious if twin ...   Feb 18 2018, 07:27 PM
jd74914   So, lots of cool responses. I am curious if twin...   Feb 19 2018, 06:09 AM
ablesnead   ..My car was in Volkswagen Porsche way back in the...   Feb 18 2018, 07:29 PM
Chris914n6   The dizzy cap is from an 80s Datsun 720 pickup wit...   Feb 19 2018, 01:00 AM
914werke   So perhaps Im incorrect, but I get the sense that ...   Feb 19 2018, 01:41 PM
Mark Henry   Not worth it IMHO, only good place to put the plug...   Feb 19 2018, 03:52 PM
pete000   Aero-VW airplane engines use the second plug as a ...   Feb 19 2018, 07:19 PM
Dave_Darling   That chamber shape looks somewhat different than o...   Feb 19 2018, 09:08 PM
Mark Henry   That chamber shape looks somewhat different than ...   Feb 20 2018, 09:18 AM
WLD419   Hello, I've been running a twinplug 2.8-4 for ...   Feb 20 2018, 09:50 AM
gereed75   Aha, great to hear from some one that’s been the...   Feb 20 2018, 10:09 AM
gothspeed   Twin plugs allows the mixture to burn quicker whic...   Feb 20 2018, 12:28 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:33 PM
