Front sway bar strengthening |
defianty |
Feb 20 2018, 08:14 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
My car didn't have sway bars from the factory and I have a Weltmeister to install at the front. I've actually already fitted it and packed it away again before I fit it once the car is painted.
In a conversation with another UK 914 owner we discuss strengthening the inner wing where the bar come through. Here's a pic of what I have at the moment. What's everyone's thought on strengthening this area? (IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1519136078.1.jpg) |
914_teener |
Feb 20 2018, 08:56 AM
914 Guru Group: Members Posts: 5,204 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If you are using a stock bar not necessary.
Bigger yes. |
ChrisFoley |
Feb 20 2018, 09:16 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If you are using a stock bar not necessary. Bigger yes. I disagree. The factory installed reinforcing plates in all cars that received factory anti sway bars. However the one Jeff Hailpern posted a pic of is total overkill for most 914s. I'm pretty sure the ones I make are the only ones with a tri-oval shape which follows the stamped area of the inner fender. |
Morrie |
Feb 20 2018, 10:10 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
If you are using a stock bar not necessary. Bigger yes. I disagree. The factory installed reinforcing plates in all cars that received factory anti sway bars. However the one Jeff Hailpern posted a pic of is total overkill for most 914s. I'm pretty sure the ones I make are the only ones with a tri-oval shape which follows the stamped area of the inner fender. Chris, I have seen your stuff in action, modified slightly to fit my friend's 911 chassis (Jamie Novak). I highly recommend this as a preventative measure, and well worth the expense. This is one of those cases where making your own part is not worth the effort when a quality part is out there. |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:29 AM |
