yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,455 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up: Front: 21mm torsion bars 19mm sway bar set 3/4 hard Rebel Racing Bushings Monoball camber plates 19mm raised spindles Bilstein Sports 2.5 degrees camber 5 degrees caster 1/16" toe out Rear 225lb springs Rebel Racing Bushings No rear bar Koni Yellows (full soft) 2.0 degrees camber 1/16" toe in Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot. Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction? Me https://www.youtube.com/watch?v=hdMUYqusga4 Evan (damn he's fast) https://www.youtube.com/watch?v=mI6O_gVzPuA |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,008 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I'm also wondering if you have a cage in this car?
they do flex a lot, twist and squirm |
Lo-Fi Version | Time is now: 4th July 2025 - 12:40 AM |
